-   -   3.6 part ID (http://forums.pelicanparts.com/porsche-911-technical-forum/1171284-3-6-part-id.html)
SFR 12-10-2024 10:11 AM
3.6 part ID
What goes here (circled)?
It’s a 964 3.6 motor, is it a vent, anyone have a part number?
http://forums.pelicanparts.com/uploa...1733854233.jpg
SFR 12-12-2024 04:21 PM
Bump
walt 12-13-2024 05:47 AM
Connects to oil filler neck with rubber hose and clamp. Don't have the part number available but will look.
3rd_gear_Ted 12-13-2024 11:25 AM
I just capped it with a soft rubber cap. Not a fan of regurgitated oil fumes in my pretty engine compartment at all. My oil tank breather goes to a wheel well mounted catch can too.
walt 12-13-2024 12:46 PM
On my 3.6 conversion it appears to mate with the filler neck using the same breather hose as an SC. Most likely p.n. 93010739900.
SFR 12-13-2024 06:35 PM
Thanks - I think I’ll put a small vent filter on it.
Ted - can you post a picture of your catch can, I’ll need to that with my oil tank breather…
3rd_gear_Ted 12-15-2024 11:11 AM
Search and check out
JAZ Products Overflow Catch Tank 1-Quart Black
Thru wall 90 degree #20 AN fitting into left wheel.
