Alternator wiring
I am replacing alternator and voltage regulator in my 74 911 with a Bosch alternator with built in regulator. I’m fairly certain I know where to hook the hot red wire and blue wire that goes to the instrument panel. I cut and capped the black voltage regulator wire. I’m not sure what to do with a white or faded tan wire that remains. I took pictures of the original wiring but they’re not helping me. I’d appreciate any help I can get.
Ron from Indiana |
"Tan" should be brown. That's the ground wire. It doesn't do anything with the VR removed, but I would ground it to any convenient nut/bolt/screw.
Thanks for your help. If I understand correctly the only important connections are red to B+ and blue to D+. Not sure but I also take brown to any place I can use for ground. Wiring diagram says D- but maybe that’s not necessary.
Either the case of the alternator or a stud/nut/bolt on the engine.
Thanks again.
| All times are GMT -8. The time now is 06:56 AM. |
