-   -   MFI Induction Chart (http://forums.pelicanparts.com/porsche-911-technical-forum/117171-mfi-induction-chart.html)
Bobboloo 07-01-2003 04:58 PM
MFI Induction Chart
I thought since the topic comes up once in a while that I would post the dimensions of the various MFI setups for the data base.
I measured all the the induction setups with the exception of the 72/73' S/RS setup stacks which I did not have available to measure. My guess is that they are they have the same inner dimensions as 70/71' S stacks.
The stacks were made of magnesium until 72' when they started making them out of plastic.
The 69' magnesium stacks had the same outer dia. on the E and S stacks. The inner bore is what is different. Same is true of the 70/71 mag stacks.
Outer diameters of the mag stacks:
69'
E & S
55mm at the top
47mm at the bottom
70/71'
E & S
55mmm at the top
52mm at the bottom
If you use the 69' stack as the limit for wall thickness. (about 4.5mm) then you can see that the 70/71 mag stacks, E or S can be bored out to be 46mm at the top and 43mm at the bottom. This is what makes them good candidates for large displacement motors. Of course, special throttle bodies would need to be built in this scenerio. i.e larger than 38mm.
The outer and inner dia. are different on all three ver. (T,E&S) of the plastic stacks. The angle of the stack varies as well. This makes the E plastic and especially the T plastic stacks not very useful for modifying for larger ports and cams. Either find the S stacks or get some mag stacks to use. Remember, the 69' stacks won't fit the later TBs' so you'll have to buy those as well.
The throttle bodies in 69' had a stud spacing of 66mm. From 70' on they used a spacing of 72mm. Therefore throttle bodies and stacks can't be interchanged between 69' and the later years. From 70' on they are interchangeable. i.e. You could put a 70/71 E or S stack on a 73' T throttle body if you wanted to.
As you will see in the chart. All the throttle bodies start with a 38mm bore and taper to their respective cylinder port. Therefore you could bore the bottom of a T throttle body from 29mm to 36mm and use it for a 3.0RS if you chose to do so.
In the chart below you see the numbers 1 thru 5. These correspond to the inner diameters accordingly.
1. Top opening of stack
2. Bottom opening of stack
3. Top opening of throttle body
4. Bottom opening of throttle body
5. Cylinder intake port.
This shows the flow pattern going down into the cylinder.
Year..69'.......70/71'.....72/73'
T
1.......n/a........n/a......35mm
2.......n/a........n/a......32mm
3.......n/a........n/a......38mm
4.......n/a........n/a......29mm
5.......n/a........n/a......29mm
E
1.......39mm....38mm....38mm
2.......35mm....35mm....35mm
3.......38mm....38mm....38mm
4.......32mm....32mm....32mm
5.......32mm....32mm....32mm
S
1.......46mm....42mm
2.......38mm....38mm
4.......36mm....36mm....36mm
5.......36mm....36mm....36mm
2.4S, 2.7RS and 3.0RS all use the same MFI setup. The only difference is the space cam used on the 2.4 motors. The 3.0RS setup is identical to the 2.7RS
Scott Clarke 07-01-2003 08:21 PM
Thanks for this great post. Its long overdue!
Bobboloo 07-02-2003 12:17 AM
If anyone has a 2.4S stack and wants to measure it and post feel free to do so. I'll update the chart.
Since the plastic stacks have a flare at the top you can measure the bore by inserting a rolled up piece of paper in the top of the stack to give you an edge that you can measure. Otherwise it's hard to get an accurate measurement due to the bell at the top.
FA-18C 03-15-2004 04:12 PM
Great MFI Info
Thought I'd bump this info and also ask the guru's a follow on Q. I just picked up a very good set of 72/73E throttle bodies with the 38mm intake and 32mm exhaust bore. I have not yet pulled my 70E bodies, but they look nearly identical with the exception of a small tube at the end of each throttle body that I do not think mine has. Is this some sort of cold start system from later cars? Since I do not have this system, do i just plug this up?
Also, since I plan on swapping them out this weekend, can someone give me a quick synopsis of the steps? Is it best to remove the whole system including the injection lines etc? Also, are there gaskets between both the throttle body and motor as well as the throttle bodies and stacks?
Tim Walsh 03-15-2004 04:22 PM
There are gaskets between the motor and t-bodies and between the stacks and t-bodies.
I belive your cold start mechanism is in the airbox.. the 72 cold start is evidently safer but I don't have any hard and fast numbers on that.
Early_S_Man 03-15-2004 04:38 PM
Chris,
If by 'end' you mean ... coming out towards the rear bumper, those two brass tubes provided vacuum, and were joined at a tee and went to the vacuum retard port on the distributor of '72 thru '76 MFI engines! Cap them off!
FA-18C 03-15-2004 04:40 PM
Thanks Warren - these throttle bodies I picked up are in great shape and i cannot wait to see what a difference they make. Any rec's on capping, just a rubber stopper?
KevinG 03-15-2004 04:47 PM
FA18-C:
I believe that the cold start system for 72/73 involved the stacks, not the throttle bodies, but of course I may be wrong.
Bobboloo:
Am I correct in interpreting that my current 2,2S MFI setup could also be used as is in a 2,7RS application, with the exception of the appropriate space cam?
FA-18C 03-15-2004 04:50 PM
BTW- not that this is a thread I saved from last July 2003 - valuable info to print and save for the MFI files.....
Scott Clarke 03-15-2004 05:23 PM
Chris-
Access to the nuts securing the throttle bodies to the heads is difficult. I removed mine while leaving the stacks in place. It can be done as long as you have good long 1/4" extensions with good quality wobbly sockets. If you can remove the stacks while leaving the throttle bodies in place, go for it. the alternative is no picnic.
Kevin-
The 2.2 space cams are not interchangable with the 2.4/2.7 space cams, so the 2.2S space cam is as close as you will get with a 2.2 pump. Gus Phister can make some internal adjustments to the pump that will ameleriorate any shortcomings of the 2.2 space cam with your 2.7. He told me that the 2.2S space cams seem to work with RS replicas, as long as you are using an S cam.
-Scott
FA-18C 03-17-2004 07:05 PM
Should get gaskets by Friday from PP, and am going to pull the system that evening. Is standard satin black paint good enough for the intake stacks or do I need a high temp paint? I do not plan on painting the throttle bodies, but would like to clean up the intake stacks prior to putting it all back together.
spinmd 02-23-2006 08:00 PM
Bobby,
Sorry to resurrect an old thread but it's what I've been searching for for the past 2-1/2 hours and 300+ posts - THANKS!
Hopefully you can tell me if my set of stacks and throttle bodies will work on my 69E engine. From your specs, I see the only difference might be the top opening of the stack if I do indeed have E stacks/throttle bodies.
I'm putting together the MFI for my '69E and have the correct pump and all the extraneous hardware, but the stack/throttle body numbers are not 1969 numbers. I have mag stacks: 911 110 301 0R, and mag bodies: 911 110 101 1R. They appear to be original to each other, i.e., never separated, but I know they aren't 1969 numbers.
Other than pure authenticity to the 69E motor, what are your thoughts on whether these will pose any problem to the operation of the engine/MFI? I may later post a new thread as to whether I should continue to hunt for the properly numbered stacks/bodies in order to maintain premium value of the car/motor combination -- any thoughts on that would also be appreciated.
Thanks!
rswannabe 02-24-2006 07:50 AM
EDITED TO REMOVE INCORRECT INFORMATION
Brooke
69911e 02-24-2006 08:22 AM
spinmd: I ran the stacks/throttle bodies from my 69E on both the original 2.0E motor and a 2.2E motor. The stacks/throttle bodies should bolt right up. I believe there is a difference in the stud spacing between the stacks and the throttle bodies. ie you can't mix 69 stacks with other year throttle bodies.
I do have my original 69E stacks, throttle bodies, and pump. Email me if you are looking for some (edbogue@yahoo.com).
Ed Bogue
Tyson Schmidt 02-24-2006 10:03 AM
The head intake stud spacing is the same from 2.0 up to 3.2.
The real difference is the stud spacing on the tops of the t-bodes for the stacks to bolt to. You can't swap stacks between '69 T-bodies, and later ones.
rswannabe 02-24-2006 10:30 AM
Sorry for the misinformation. Thanks for the correction.
Brooke
Tyson Schmidt 02-24-2006 02:14 PM
Brooke
No problem. You were really close anyway! Easy to make that mistake.
David E. Clark 03-01-2006 02:55 PM
Please take a look at the Ultimate MFI resources thread and add your links and resources. It will make a great resource for all of us. SmileWavy
jluetjen 03-16-2009 01:18 PM
I recently took my intakes apart and made the following measurements which I've used to correct the data in the above table:
T
E
1.......41.5mm.38mm....38mm
2.......33mm....35mm....35mm
3.......33mm....38mm....38mm
S
Mr Beau 10-25-2012 05:30 PM
Are there part numbers of the various stacks? Do the plastic ones have different embossed part numbers as the outer dimensions are the same?
RobFrost 05-24-2024 11:46 AM
What's the story with the E step down in MFI diameter?
The bottom of the E MFI stack is 35mm and the intake therefore jumps to 38mm for the throttle body. Surely it'd work better if there wasn't a sudden step out at the junction? Just contemplating boring the stacks out to 38mm.
Jonny042 05-25-2024 05:44 AM
The step serves a purpose and is there for a reason.
It jumps up to 38mm for the throttle plate itself, but necks down again at the throttle body exit to the smaller diameter.
The throttle plate and the throttle shaft both take up room in the bore and reduce the cross sectional area of the system. That "bulge" in the flow path allows for the air to go around the obstruction without having to speed up and slow down again.
If you want to improve the flow capacity beyond the "S" dimensions it's theoretically better to increase the diameter of all the parts of the system in equal amounts.
Originally Posted by Jonny042 (Post 10279014)
After years of all this kicking around in my head, work has finally begun on the MFI system. I've been accumulating parts, documentation, knowledge, tools, and equipment to make this all happen (and work!) the system will consist of:
- 911"T" throttle bodies enlarged to 40mm throttle plates, tapered to 38mm at the head
- small port SC heads ported to 38mm intake port, machined for MFI injectors
- 911"T" plastic stacks taper bored to 38mm bottom exit
- 911"T" pump converted to RS pump specs and calibrated for the 3.2SS motor
This weekend I started to work on the machining for the throttle bodies. The tricky part is the taper from 40 to 38mm but I ground a tool to make it happen and it's working out:
http://forums.pelicanparts.com/uploa...1544449666.jpg
There is a big difference between the "T" throttles and mine!! They are going to have to flow more than twice the air to support the 250Hp target.....
http://forums.pelicanparts.com/uploa...1544449872.jpg
Top:
http://forums.pelicanparts.com/uploa...1544449951.jpg
Bottom:
http://forums.pelicanparts.com/uploa...1544450020.jpg
