Rear center reflector
I am going to replace the tail light gaskets which I have. I noticed that the gasket that runs along the bottom of the center reflector needs replacement as well, however I cannot locate the part anywhere on Pelican. I may just be using the incorrect search words. Can anyone steer me in the right direction? Thanks!
Jay, it would help to say what model-year of 911 you have.Also go to your signature and show where are you located....
the part number under the real reflector is this...91150308505..you can get it possibly from our host Ivan
1985 911 with original 501 645 miles...807 319 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 12-25-2024 at 09:56 PM.. |
Recently purchased one from Pelican. Quality part.
Tony 1973 914 2.2 FAT Black 1974 911 Targa Lime Green 2018 Macan GTS White 2019 Targa GTS Agate Grey |
