Porsche Crest 1976 Top Dead Center - how to find
I have a 1976 2.7L motor that I am converting over to ITB and fuel injection. I am adding a Clewett CAM sensor.
Instructions say
" rotate engine through a cycle stopping 120 degrees before Z1 on the compression stroke"
Assuming this is for cylinder 1
I have the engine out of the car and the valve covers off
I can find TDS for cylinder 1 using a stick to see when the valve is up.
How do I know if I am on the compression stroke (vs exhaust)
Does anyone have a good method. I need to know before I drill for my CAM sensor.
Jared
73 Porsche 911 Targa
57 Chevy 3100
Old 05-11-2025, 10:42 AM
Full Send Society
Just went through this.
Check the valves on cyl 1- if they’re loose or wiggly then you’re on compression for cyl 1. Confirm that cyl 4 valves are not loose.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 05-11-2025, 11:36 AM
Is there anyway that is a little more confirmed to check besides if they are wiggly. I need to drill the Cam sensor location and don't want to be wrong. Was hoping there was another way to do this to be certain.
thanks
Jared
57 Chevy 3100
Old 05-11-2025, 02:09 PM
If the valve is closed, the rocker is loose and the intake on #4 is opening so it’s not loose.
Bruce
Old 05-11-2025, 02:53 PM
Full Send Society
You can look at the rockers to see if they’re on the lobes. Other than that, the wiggle method is the best way. Do it a few times and it’ll make sense. If the rockers aren’t loose then you’re either not at cyl 1 compression or they’re too tight and it’s time to adjust.
-Julian
Old 05-11-2025, 03:54 PM
It's a 914 ...
stownsen914's Avatar
Yep agree. You'll be able to tell if the valves are open (it would be about 1 mm on your engine) vs. totally closed. If closed, you'll have the .004" valves lash like when you check your valve clearance. I assume that's what is meant above by wiggly.
Old 05-11-2025, 08:29 PM
Thank you everyone. I believe I have it figured out. That wiggle is slight, but I can feel the difference. Now on to drilling for the CAM sensor. appreciate all the replies.
Jared
57 Chevy 3100
Old 05-12-2025, 08:31 AM
Need to use piston stop and degree wheel or you are just guessing
Old 05-13-2025, 11:03 AM
If you haven't disturbed the distributor, pull the cap off and see if the rotor is pointing to #1.
You can also remove the other 5 plugs, leaving the #1 plug in, then rotate the engine over until you feel and hear compression on the cylinder.
Old 05-13-2025, 11:32 AM
