-   -   Help with Engine compartment light wiring connection (http://forums.pelicanparts.com/porsche-911-technical-forum/1172113-help-engine-compartment-light-wiring-connection.html)
GTT 01-01-2025 08:05 AM
Can someone shed some light for me on how the wiring harness plugs into the engine compartment light housing? I'm reassembling a car someone else took apart and cannot figure out how the wires are suppose to connect to the housing. Are they supposed to somehow plug into the two little brass fittings on the backside of the housing?http://forums.pelicanparts.com/uploa...1735751266.jpg
group911@aol.co 01-01-2025 08:30 AM
On the other side of the fixture, there are posts that those 2 wires screw into.
Should be pretty evident which one is the ground side
GTT 01-01-2025 09:25 AM
Thank you! Now I see the housing comes off the top. Appreciate the help!
ErrorMargin 01-01-2025 09:29 AM
I’ll be doing this soon on my car, please post pictures of how it connects and how the wire is routes from the light down to the point where it joins the main wire harness… I’m curious how the harness is attached to the deck lid and how it transitions to the body.
GTT 01-01-2025 01:23 PM
This is how I ended out routing the harness, but since I didn't take it apart, I'm not claiming to be an expert. I saw a couple pictures on another thread so I think this is correct. http://forums.pelicanparts.com/uploa...1735770162.jpg
group911@aol.co 01-01-2025 01:37 PM
That looks about right. Just make sure the loom doesn't go through any metal holes that aren't protected by a grommet.
Don't forget that the park lights need to be on for the light to work.
It should also turn off when the cover is rolled closed.
ErrorMargin 01-02-2025 07:21 AM
Originally Posted by GTT (Post 12383237)
This is how I ended out routing the harness…
Can you show how it routes from the deck lid into the engine bay, and how it travels in the engine bay down to the wire harness bundle?
GTT 01-03-2025 04:25 AM
Mine goes from the light toward the back lip of the deck, then travels down the left side as you are looking into the compartment and is attached to the left hinge before meeting the rest of the loom. It is held in place with metal clips. http://forums.pelicanparts.com/uploa...1735910632.jpg
David Inc. 01-03-2025 05:27 AM
Does that light ground to the decklid, or ground wire back to somewhere else?
group911@aol.co 01-03-2025 05:40 AM
Brown is ground
GTT 01-03-2025 05:42 AM
I am not sure where the brown ground wire on the light housing attaches at the other end. I didn't remove the whole harness - the housing was just disconnected from the light pig tail when I got it. Sorry I'm not much help.
timmy2 01-03-2025 06:30 AM
Grey connects to a WECO single connector at the 6 pin tail light drivers side.
Brown goes to the ground stud behind the fuel filter.
ErrorMargin 01-03-2025 08:31 AM
Thanks, that is just what I needed!
