-   -   Disconnecting Idle Position and WOT Switches (http://forums.pelicanparts.com/porsche-911-technical-forum/1172208-disconnecting-idle-position-wot-switches.html)
josephvman 01-03-2025 07:49 PM
Is there a trick to disconnecting these switches, or do they just pull off? Mine are tight and I don't want to force them without checking. Thanks!
ant7 01-04-2025 02:07 AM
Try warming them up a bit, it will help to stop the plastic breaking when you pull on them, but yes, they should just pull off, there is a spring wire running through the clip, which can be a bit tight.
Good luck.
Ant.
john walker's workshop 01-04-2025 08:39 AM
Dental pick and lift the wire clip.
