Has anyone converted G body wipers to 993?
I know Singer does this, but I was hoping to see if anyone has picks or info on how to mount 993 wiper assembly into a G body 911.
I have a customer requesting that I convert his car.
The big problem is that I need to keep all his venting intact.
Any input or photos would be greatly appreciated?
Cheers, Louie
Old 01-04-2025, 02:55 PM
In general I’m glad I have 964s instead of 993s. But I do love those wipers! I wouldn’t mind not having to adjust valves either.
Old 01-04-2025, 09:00 PM
Have you tried a search on here, I’m pretty sure this has been done before and documented?
Old 01-04-2025, 11:19 PM
evan9eleven's Avatar
Kits are available for this, ST Parts in Germany or Stuttgart Classica both offer them.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 01-05-2025, 02:19 PM
PCA Member since 1988
What's the advantage?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-05-2025, 10:55 PM
I asked the same question, and the conclusion was none (other than that they look cool.)
https://forums.pelicanparts.com/porsche-911-technical-forum/1150937-let-me-hear-those-993-seat-time-rain.html
2004 Boxster S
Old 01-06-2025, 02:08 AM
https://www.stuttgart-classica.com/body/993-wiper-kit?rq=Wiper
Old 01-06-2025, 03:04 PM
Grease Monkee
Seems like a bit of work for low return. But if you're into it go nuts.
Personally I just want to reverse the wipers so my view out is unobscured.
86 911 Carrera Coupe
99 996 C2 Coupe (former)
Old 01-06-2025, 03:45 PM
A930Rocket's Avatar
I have no idea what the 993 windshield wiper blades look like.
If I recall correctly, there was a brand of windshield wipers, that had two blades per
unit. Seems like somebody could 3-D print an adapter, to install two blades on a single arm…?
https://a.co/d/8zZgz1n
Old 01-06-2025, 07:21 PM
I thought about doing it and then someone pointed out that if they were reversed, the water from the last wipe runs up the windshield instead of being blocked by the blade.
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 01-13-2025, 10:10 AM
Grease Monkee
Fair point but 90% of the time I'm driving the car it isn't raining. If it's raining and the wipers are on they'll be clearing the water anyway. Give and take either way
Old 01-13-2025, 01:33 PM
