Transmission removal.
Morning All,
I have an 82' SC Targa, Can you remove just the transmission and leave the engine in. I want to use a lift with a transmission jack and it's much lighter that way.. Will the engine tip down in enough in the front? THANKS MUCH, -Bill |
no you cannot.....shift rod is way to deep inside the body
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
