Fuchs Color Match
I purchased a brand new pair of Fuchs 16X8 to swap my 7's at rear. However, my original 16X7 has a slight color different than the new set. both are black center although one is a little shinnier than the other set. Where in LA do you recommend taking to correct this issue or is it cheaper to buy a new set of 7's and sell the old one?
Are you talking about the color of the petals or the center cap? If the petals, try rubbing Vaseline on them with a microfiber. It should polish them up, they may match better.
Mark |
Peter Nguyen
The fuchs guy is in LA area Contact him He may be able to just match the black center s without a full restoration |
I just did this with 2 new 8" ones and polished and sealed all 4 to get them to match. Simple and it worked for me.
@steven C do you mean you did it with Fuchs guy? or DIY?
satin is the proper finish.
Good luck. |
| All times are GMT -8. The time now is 09:05 PM. |
