9magazine's Avatar
Replacing 911 Door Skins
Does anyone have any tips or advise on removing and installing new metal outside door skins on the 74-89 Porsche 911's?
Thanks,
Brian Minson
9, The Porsche Enthusiasts Magazine
http://www.9magazine.com
Coming soon for you Mercedes-Benz owners, Prestige Magazine
http://www.benzmag.com
Old 07-03-2003, 01:40 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
It's really quite simple. Did you have a specific question about it ?
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 07-03-2003, 02:57 PM
Unregistered
sammyg2's Avatar
Wouldn't it be easier to just unbolt the old door and replace it with a good used door and paint to match?
good used doors are readily available and not that expensive around here, maybe that isn't the case in other places. .......
Old 07-03-2003, 03:11 PM
9magazine's Avatar
Kevin,
Are there any unique tricks to removing the skin, and replacing it? Our body shop guy has replaced door skins on other types of cars, but never a Porsche. We just want to see if there are any tricks to make the process easier (ie. do this in order to do that...)
Thanks,
Brian Minson
9 Magazine
Old 07-03-2003, 03:30 PM
nostatic's Avatar
another magazine? No offense, but shouldn't you get the first one right before going for number two?
edit: allow me to clarify. I haven't seen a recent issue, but the current web site has got to go. Given the design and content for the online presence, it is hard for me to consider even looking at the magazine. ymmv.
Old 07-03-2003, 03:32 PM
1.367m later
KevinP73's Avatar
Porsche doors are actually easier than most because you don't have an upper window frame to contend with. Grind the edge of the damaged skin to remove it and replace with the new outer skin. Spot weld the new skin as outlined in the factory repair guide and seam seal when done welding. I like to apply a bead of Wurth panel adhesive before spot welding to give that extra "solid" sound to the finished job.
Old 07-03-2003, 03:43 PM
