CIS Journey / Rabbit hole
Hello All,
Working on dialing in the CIS system on my 76 911s with a 83 3.0 SC engine. I say 83 as it doesn't have a sump plate. Picked up the car a month ago and had a great drive home ( http://forums.pelicanparts.com/porsche-911-technical-forum/1172270-76-911s-hotrod-first-drive-phx-sea.html ). I had drafted a list of things to change with the car but 49 yr. old cars have a way reshuffling the priority list as they see fit. Queue the fuel pump failure. Old pump looks to be the original 911-608-110-56 style that had been leaking based on the build up. Decided on the much more affordable Bosch 69430 at a tenth the price. http://forums.pelicanparts.com/uploa...1738475018.jpg Car started running rich (back fires at partial throttle) so that meant it was time for a fuel pressure tester kit. Not sure if the change in fuel pumps affected system pressure but the new pump was delivering CSP of 2.8 bar, so time to get familiar with the fuel distributor. After running the pump the CCP (with WUR unplugged) max'd out at .9 bar. CSP stayed in the 2.9 bar range. http://forums.pelicanparts.com/uploa...1738475632.jpg Okay time to mess with the fuel distributor system pressure. http://forums.pelicanparts.com/uploa...1738475680.jpg Had to work my way up to four washers (several tries later) added to the check valve/pressure screw (only three copper washers shown) and ended up at 4.9 bar. Success! I am a little concerned with the number of washers required. Is that an indication of something wrong with my fuel delivery system? http://forums.pelicanparts.com/uploa...1738475979.jpg Checking the CCP pressure with the WUR element unplugged I saw 1.6 bar with a WUR temp of 7 C. That seems out of spec. Anyone care to chime in? Also checked the CP with the WUR plugged in for four minutes with no change in CP. Not ideal (I think). Getting 11.6 vdc to the WUR plug and the WUR element is showing 24 ohms resistance. Pulling a vacuum on the lower port didn't change the CP but it did hold a vacuum. Forgot to chech the upper vacuum port. Once warmed up the car runs pretty well with a nice regular 1K rpm idle. Still has a hesitation between 2k-3K and occasional exhaust backfire but fewer back fires at partial throttle after adjusting the SP. The butt dyno is saying the car doesn't pull quite as hard in the lower <3K rpm range. So, am I rebuilding my WUR? It's a 045 if that is relevant. Any suggestions on next steps would be appreciated. Cordially, Roger |
Fuel Distributor………
Roger,
Could you post a picture of the fuel distributor showing the Bosch ID #?. Thanks. Tony |
Photo of plate. The printed numbers are 0 438 100 031. The stamped numbers are easier to read. http://forums.pelicanparts.com/uploa...1738548243.jpg Thank you, Roger |
The fuel tank filter should to be cleaned before changing the pump.
The pump mechanism doesn't like grit whatsoever. Add an inline filter, not easy but needed. |
I'd suspect a blockage on the fuel tank return firstly. Remove the accumulator return line and blow into it. Then I'd suspect a blockage between the fuel distributor and fuel pump.
The fact that the fuel pump showed leakage is maybe an indicator it's under back pressure, so maybe the latter is more likely. Check fuel filter and path. There is also a min spec on fuel delivery unloaded. Phil |
During the whole adding spacers drill there were a couple of times where the system pressure spiked to 7.5 to 8 bar. I attributed that to my hand modified copper spacers being slightly too large. Filing down the OD seems to have addressed the overpressure situation. I'll be sure to check the engine compartment fuel filter and collect a unloaded fuel system delivery performance. My weekend calendar is filling up. :) Thanks for the troubleshooting help. Roger |
CIS Troubleshooting………
Roger,
Test the FP delivery rate before the fuel accumulator. You should get at least 2 liter per minute. Or 90+ psi. with delivery valve closed. Make sure the FP has both volume and pressure in spec. Tony |
Tech spec book
https://de.scribd.com/document/736191799/911-all-78-81 |
Phil |
For those who might like a washable Filter between the Tank and Pump, I offer this..... http://forums.pelicanparts.com/uploa...1739027450.jpg It is also available with a Shut-off valve that allows periodic cleaning without draining the Tank. For info, please email me: len.cummings @ verizon.net but without the spaces. Please, NO pm's as my box is almost always FULL. Thanks. Len :) |
Len,
That is good fix for a known Porsche design flaw. (gasping sound goes here) |
These filters were intended for the original Dansk Fuel Tanks that had internal sediment and caused multiple Fuel Pump failures. Dansk has since corrected this issue and they now seem to be a good choice as a replacement. I am happy to help with any fuel hose / line questions. Been doing this since 2004, and now retired. With my wife Susan helping and keeping me on my toes we are doing what we can to help preserve these wonderful vehicles for generations to come. Have a great Porsche day everyone. Len :) |
Never seen before. interesting! Is there a part no. available for these filters? Thomas |
| All times are GMT -8. The time now is 12:35 AM. |
