Random oil leaks! Should I be worried?
So I’ve noticed I have a leak under my oil tank and also around some random nuts on the engine.
Should these be concerning? Or do I simply re-torque those nuts? 🙄 Oil Tank (possibly a hairline crack) ![]() Right lower valve cover nut ![]() Crankcase ![]() Another crankcase nut ![]() I also noticed THIS: ![]() Last edited by 911TT33; 02-05-2025 at 03:48 AM.. |
I would lose sleep over all that, but that’s just me. Try replacing washers add some sealant if necessary. Oil tank will only get worse over time have it fixed or replace. I would replace that cv joint as well.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!! |
Kind of Blue
The CV joint boot would concern me. The rest would not. After four years in a mag case car, if I worried about a drip or two of oil, I'd never sleep.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
These leaks aren't detrimental, just annoying. I had the exact same issues and fixed them when it was convenient/servicing. Throw some cardboard under the engine and get to it when you get to it.
Counterclockwise?
Nice and clean!
Just keep cleaning. Change the boot though.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Oil tank might be from the sender seal, easy peasy
Cv boot for sure, if it hasn't many miles with a torn boot I'd rather clean and reassemble an og joint in good condition with a boot replacement
Instagram.com/timofthevalley |
Engine looks pretty clean. Let me guessing. Fresh overhauled engine? Or at least cleaned engine but not overhauled yet? And now filled a synthetic oil, supposingly 10W60?
Oil tank goes bad due to corrosion. Can be fixed relatively easy as others already wrote, by removing it from the car alone without tearing out the engine. Are there more leaks on the engine? Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Comments:
The torn CV boot needs replacing, this would include cleaning and new grease for the CV joint. Suspect that the weeping adjacent to the oil tank drain plug is spilt oil from the last time it was drained that wicked up into the seam. Suggest that you clean off all the oil leaks with solvent and monitor. Cheers |
Car came back from the exhaust fabricator yesterday and last night whilst inspecting the undercarriage, I noticed all those leaky bits. I guess I’ll tighten the nuts and get that tank cleaned out and welded along that bottom seam. And yes, I’ve filled it up with 10W60 oil. 😁👍🏼 |
I wonder if I can just use some JB Weld along that seem to seal it up for now? |
Please read this recent thread, we had a discussion on that. I wrote sth why I suppose that 911 elder engines with either no or decades ago overhaul may start leaking with synthetic oils...
Keyword seal /elastomer swellers https://forums.pelicanparts.com/porsche-911-technical-forum/1173217-10w60-synthetic-oil.html Thomas
Twin Turbo conversion with all that stuff amd them sealing leaks with JB weld??? Really??? I gotta out here...
Still here
“ExtremeHeat™ is formulated to allow for repairs to iron, steel and metal in high temperature environments (1000°F / 537°C). When fully cured, this metallic compound can be drilled, machined or sanded. It is great for repairing cracks, small gaps, seam connections or holes in exhaust manifolds, pipe connections, mufflers, catalytic converters, outdoor grills, fire boxes, gas and commercial furnaces and water heaters. This product is water based, non-flammable and contains no solvents or Volatile Organic Compounds (VOCs). GREAT FOR Exhaust Manifolds Tail Pipes Mufflers Engine Blocks Duct Work Heat Exchange Units Fire Box / Fire Place Outdoor Grills USE ON Automotive Metal And More” |
Still here
The standard JB weld stuff is fine. Having said that, if the leak's due to rust, I would replace it. |
Valve covers - make sure you have the right aluminum washers so they seal properly
Oil tank- empty the oil and stick in a finger to feel the seam from the inside. You can generally feel if there’s rust there or not
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
