Adapters for 3.2 Carrera Manifold On 3.0 SC Heads
Does anyone actually make an adapter?
People have before mentioned Turbokraft, but the spacers they make and sell are to adapt the 3.2 manifold to the turbo heads. I also reached out to Clewett and he doesn't make them either. I'm looking for a a specific spacer that fits between the 3.2 manifold and the 3.0SC (big port) head and has a smooth transition. This way, on the top side of the spacer, we use a traditonal 3.2 gasket, and on the bottom, we use the normal 3.0SC gasket. Is anyone actually making this?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP Last edited by mikedsilva; 02-14-2025 at 03:40 PM.. |
Email Chris at TK - they may be able to do a custom size. They did for me several years ago when I put a ported 930 intake on my SC heads.
If I cannot find someone that makes a dedicated spacer, I guess I'll buy another set and sit there with a die grinder again
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
When you are done with the die grinder on an adaptor-could you post a photo ot two?
PCA Member since 1988
Or use a 3D printer to make your own adaptors.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
