Flywheel & Clutch Dimensions
Anyone got a 3.2 engine with a G50 in this kinda state? I’m after the distance from the gearbox mounting surface on the engine to a) the front face of the flywheel b) the front face of the ring gear c) the point at which the clutch fork goes behind the ears on the throw out bearing?
Be most helpful if you did.
Cheers.
P.s. mine is not standard so hence I’m asking 😉
Old 02-11-2025, 09:25 PM
