Bull Nose Wheel Studs
Does anyone have a source for 66mm bull nosed wheel studs?
Thanks, 50/50 |
bump?
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
MSI Racing Products in North Carolina is what you are looking for. This is the industry standard for non-centerlock race cars, and they are totally worth it.
MSI Racing Products |
Tarett Engineering sells them
I bought my MSI from Tarett along with the nascar lug nuts. Stoked with them.
‘70 911E ‘82 911 SC Targa ‘86 944 Turbo ‘90 OM606 Swapped SWB 300GD IG: @JackSchroederCreative |
Thanks for this post / query never heard of MSI. great stuff
Studs: 10.0034 $11.58ea
Nuts: 40.0006-B $4.48ea
Just installed my 90mm bull nose rear studs from MSI yesterday. And I also bought their wheel nuts too. Will get the fronts on today.
Just about every NASCAR team sources from MSI
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
cycling has-been
73 911T MFI, 76 912E, 77 Turbo Carrera |
I couldn't get MSI to return an email. They had no pricing listed on their site.
I ordered my MSI studs and nuts pictured above from Tarett. I went with 52mm studs front and rear on 15x7/8 fuchs so I can slightly space out my wheels and because I felt like getting longer studs defeats the main purpose of competition studs overall, as you will spend extra time threading down the lug nuts when they are made to speed up the process. If you look at nascar wheels you will see the nuts end where the thread ends. MSI Wheel Studs MSI Lug Nuts
Also, anything longer than the 52mm rear competition studs (or 66mm regular rear studs) you will have to pull your rear hubs, while the 52mm studs you can finesse in with the parking brake spring removed.
Yeah, they are pretty great to deal with, glad you got all sorted.
Porsche Addict
What is the length of stock '86 Carrera wheel studs?
Lawrence - 1986 911 Carrera Coupe Grand Prix White 1959 Land Rover Series II 1962 Volkswagen Sedan Ragtop 1959 Porsche 356A Coupe 1971 Porsche 911T coupe |
Titanium User
45mm 65-89 excluding turbo
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Msi are the best.
Since we're listing long stud sources:
Paragon products https://www.*****************.com/Wheel-Stud-p/wheelstud.htm 8045 Wheel Stud - 100mm, $9.85 PP904.341.671.00, Wheel Stud - 45mm, $7.77 PP901.331.671.00, Wheel Stud - 52mm, $8.59 PP911.331.671.00, Wheel Stud - 66mm, $6.91 PP901.331.671.01, Wheel Stud - 72mm, $8.59 Bullet nose versions, $11.95 ea. no affiliaton S |
MSI 90mm studs compared to 66mm Porsche
The 90mm MSI is actually 85mm of thread. (that's an ARP CV bolt below the studs) ![]() Studs installed in the front of my '86 with 996TT brakes ![]() Longer studs so I can run a 15mm H&R spacer ![]() Fikse 17x9 mounted with the 15mm H&R spacer and with the MSI wheel nuts. I'll eventually paint them black, they come this color. I have enough remaining stud that I could run a 25mm spacer if I needed to.
