Electrical plug in front of battery?
New to me 1987 Carrera. After replacing the battery and making a mount, I found a plug that isn't connected to anything. I had removed my condenser cooling fan to remove the old battery, and found this tucked up in the wiring harness.
A cursory look and some hunting for other engine pictures didn't reveal what should be there. Just untangling the mysteries as I was trying to fix my non-functioning dash blower cool air fan. Thanks! |
Is it possible this connects to the horns? I just pulled off my steering wheel pad and there's no wire at all visible to connect to the contact on the pad. My turn signals don't cancel, so I was looking into that and discovered there's no wire for the horn at all.
Thanks! |
I'm guessing it is for the headlight washer pump on Euro cars, just not used in US models.
Mark
1979 911SC Targa |
Been here a while
Fog lights, headlight washer or windshield washer pump. Most likely candidate is the blower fan for the AC condenser. Based on the photo, it looks like you don’t have a condenser fan.
looking for 1972 911t motor XR584, S/N 6121622 |
Read his post. He said he removed the condenser fan to install battery. Condenser fan connector wires is white/green and brown.
This dangling connector is indeed the one for headlight washer. When washer is present, there's a matching black connector with cable that goes thru the big black grommet visible on left and then to the pump and reservoir inside fender.
Gilles RoW 88 Carrera coupé |
