-   -   Removing speed for odometer gear replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/1174361-removing-speed-odometer-gear-replacement.html)
nealf2002 02-24-2025 10:20 AM
Hi I forget how to disconnect these wires?
Can anyone help?
Thanks.http://forums.pelicanparts.com/uploa...1740421184.jpg
Flat6pac 02-24-2025 11:28 AM
Simply pull out of the instrument
Bruce
john walker's workshop 02-24-2025 06:27 PM
Pocket knife blade under the rim and twist. That way you don't pull the wires off and leave the socket.
dictoresno 03-02-2025 10:59 PM
those are for the speedo illumination, you pry under the entire metal lip of the bulb out which is press fit in. pry under the small lip to remove the entire assembly as one piece. the metal sheathing acts as the ground to the housing. do NOT pull on the wiring itself.
https://i.imgur.com/iV6K3u0l.jpg
