Early SWB ignition switch bezel
The ignition switch nut I have for my early SWB does nut cover the area in the dash for the switch completely. The dash has an indentation were the key switch goes. The early ring does not cover it like the later ones do. So what goes behind it? Any bezel rings that would cover the indentation are threaded and do not fit the small early switch. A giant washer is kinda what’s needed.
The early switch shows the small nut but no backing plate. The one with the wide bezel is late up to 73. Early spade connections late bullet. So what covers that part of the dash?
Old 03-11-2025, 12:56 PM
Paul Shugert's Avatar
Under the early bezel nut should be a large plastic washer.
It is approximately 3" Dia and 3mm Thickness
Might be NLA
That's all folks..
Old 03-12-2025, 06:14 AM
Just make one!
Old 03-12-2025, 08:30 AM
