Randy Webb's Avatar
heater box hose
Does anybody know the p/n for the hoses that connect from the heat exchangers to the heater flapper boxes for a 1973.5 911?
Pelican only lists from 1974 on, and I can't find it in the PET -- anybody know what group/sub-group it's in?
Thx!
Old 01-19-2004, 07:21 PM
RETIRED
Joe Bob's Avatar
Same stuff....it's spring loaded....adjust to length.
2012 ML350 3.0 Turbo Diesel
Old 01-19-2004, 07:23 PM
Randy Webb's Avatar
So is the aircraft piece the same thing one uses for the flapper box to exchanger run? Or the OEM?
Old 01-19-2004, 07:45 PM
RETIRED
Joe Bob's Avatar
No....the bottom hose pieces, the ones from the HEs via the flapper to the ducting in the body are different from the the ones coming off the fan.
The bottom ones are heat resistant vinyl or something and have a coiled spring in it....the top ones are stiff foil lined and precut...they resemble the stuff early VW bugs used...........
I just happen to have a set up someplace in the garage that I can take pics of if you need.....gotta go beat the kids up and put them to bed....
Old 01-19-2004, 08:08 PM
