Tach problem, '74 Euro Carrera
I've recently acquired a '74 Euro spec Carrera w/ a regular 911T engine/tranny. I'm trying to sort out the gauges (only the oil pressure worked when I bought the car) and I'm a bit stumped w/ the tach.
The Blk/blu wire from the tach is loose in the engine compartment w/ a spade connector on the end (good continuity to this point). It is not going through the regulator panel (ie. the 14 pin connectors). The tach is getting power and has a good ground. I've used a jumper wire from the Blk/blu to coil terminals and distributor side w/ no results.
I see that some of the wiring diagrams (none of which are perfectly accurate for my car) show an RPM transducer or similar device, and of course I don't have one. Should the wire be connected to the ignition box instead? If so, where?
Thanks for any help you guys can provide.
Francis Kennette
Belle River, Ontario
Old 07-03-2003, 11:55 AM
Paul Thomas's Avatar
Unless i am mistaken, the T has a points type tach and the Carrera has an electronic one. are you sure that you have the right tach for the motor? I had to switch tachs when i put the later motor in my T body.
Paul
My ignition is retarded.
Old 07-03-2003, 12:12 PM
Paul
How do I tell the difference between an electronic and points type tach?
Thanks,
Francis
Old 07-03-2003, 12:19 PM
Early_S_Man's Avatar
Porsche Crest
Francis,
ALL '73 thru '77 Carrera 911's used points-type distributors and tachs!!!
Hopefully ... you only connected the Black/Blue wire to the low (ground) side of the 'coil' ... as the high [460 Volt, CDI pulses] side could fry your tach!!!
It certainly would be safer for your instruments ... had you taken a bit of time to figure out from the '73 - '77 schematics that the tach only needs to be connected to the distributor points to get the proper signal!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-03-2003, 12:31 PM
It turns out i am mistaken, they didnt change that until 78. My apologies.
Paul
Old 07-03-2003, 07:30 PM
