Help removing G50 coupler from trans
Hi everyone,
I'm trying to access the collar bolt that holds the G50 coupler to the transmission. I can't get it from the inside, and the rubber boot doesn't want to slide towards the front to expose the bolt. Before I rip that boot I thought I'd check that I'm approaching this the right way! Its definitely cramped under there so its tough to get 2 hands on it. I'm installing a short shifter wanted to replace the coupler bushing, but need to get it out first ;) Thanks in advance! http://forums.pelicanparts.com/uploa...1741186519.jpg http://forums.pelicanparts.com/uploa...1741186519.JPG |
Try disconnecting the boot on the body and sliding it rearwards. Pull it into a gear that allows access.
The boot is retained via a flange on the body underneath. You can CAREFULLY pry it off the flange, but use a plastic tool; you don't want to tear it...
Thanks guys, that is exactly what I needed. I was worried about tearing it but got it off with a plastic tool this morning. Appreciate you!
MJ |
Coupler and Shifter installed. Definitely made getting the shifter rod into the shifter easier with the extra space having the coupler out of the car.
JWest Coupler installed http://forums.pelicanparts.com/uploa...1741623703.JPG JWest shifter http://forums.pelicanparts.com/uploa...1741623703.JPG |
| All times are GMT -8. The time now is 10:28 PM. |
