Help !?! Heater Ventilation cables?
I can find these in the Porsche PET. Any idea out there? Heater Ventilation cables? 1978 Porsche 911.
Old 03-07-2025, 01:58 PM
It is always best to specify what year and model you are working on. I randomly pulled up the PET for the 1983, so it may or may not be applicable to your specific car. at any rate if it differs, look at Illustration 813-00 of your respective PET. Those are referred to as BOWDEN CABLES. I think Item 37 (quantity 2) in the below image is what you are looking for.
Old 03-07-2025, 02:57 PM
You're right I fixed it. And thanks for looking at the PET. 37 can be bought, but the cables coming out of the control unit don't seem to be available or show part numbers in the PET.
Old 03-08-2025, 03:51 AM
you can use piano wire. it comes in gauges from a number 13 (thinnest) to 22.
talk to your friendly neighbourhood piano tuner; he will have some.
Old 03-08-2025, 04:00 AM
LOL. How would that work. There is a wire inside and it needs to slide back and forth.
Old 03-08-2025, 04:04 AM
it is the wire inside that is the wire that gets replaced with the piano wire. i've used it for years.
Old 03-08-2025, 04:44 AM
GREAT. Do you remember which size Piano wire?
Old 03-08-2025, 04:49 AM
i don't but it will be one of the higher numbers, maybe the highest.
they will have it in spools and can cut off a length for you.
maybe you can bring a short sample or measure the thickness of what's on the car now and get the closest match.
it is good wire and far better than anything you will find at a hardware store.
hardware store wire - snare wire? - will bind on the inside of the outer sheathing when you need to push on it.
Old 03-08-2025, 05:17 AM
PERFECT! I'll go check today. Thanks.
Old 03-08-2025, 05:25 AM
McMaster sells it.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 03-08-2025, 05:32 AM
What year is your car?
Old 03-08-2025, 09:20 AM
1978. Euro.
Old 03-08-2025, 09:48 AM
Originally Posted by turbotoo View Post
1978. Euro.
for a 78 you should have the 6mm OD on the cable housing. there are 2 different lengths 800mm and 1080mm (associated part numbers below:
911-613-111-70 (800mm)
911-613-111-80 (1080mm)
If you should happen to have the 5mm OD housings which should have ended in 77, the part numbers would end in -50 and -60.
Old 03-08-2025, 10:42 AM
fallingat120mph's Avatar
Food for thought:
I needed the wires with one of my previous 911's (1986) Not sure what the previous owner tried to do... I needed it fast and found a used one for very cheap.
The one listed above might be your year...piano wire would be a ton cheaper I imagine. Pretty sure I have heard of some using piano wire with success. It wasn't a normal wire if memory serves, but nothing special.
Erik
1986 911 Coupe
1986 911 Targa
Old 03-08-2025, 05:11 PM
Thanks!
Old 03-09-2025, 05:05 AM
