First engine/trans drop...pressure plate question
RE: '87 with G50 trans
Nine bolts off of starter ring/pressure plate and nothing will budge. How do you get this d*** thing off? I read Bentley, Wayne's 101 Projects, and factory manuals. I quote the factory manual, Repair Group 30-117, Removing (clutch), Section 1. d. : "Remove clutch retaining bolts by slacking bolts uniformly (I did'nt do this). Remove clutch from flywheel." That's pretty much where I'd like to be right now. Finding a decent slide hammer to use on the release shaft was a godsend today. Thanks AutoZone for the loaner. Oh yeah, mine has the original G50 fork/shaft assembly. Bearing surfaces in good shape. I now know what needle bearings are. Guess how many are in each bearing. I think I found them all. So, how do I get pressure plate off? Cheers, Bob Sauerteig:confused: |
I haven't done this with the P car but most other clutch pressure plates are also located inplace by 3 to 4 dowel pins. You simply have to carefully pull or pry the pressure plate back away from the flywheel untill you clear the dowel pins, a gentle pry with a large srcewdriver will help.
I had the same problem. Like movin said, pry with a large screwdriver gently.
Thanks guys.
I'll go that route. I hope to have some pics to load this weekend. By the way, there are 23 needle bearings in each shaft bearing. I counted them as I picked them up in the driveway! Cheers, Bob Sauerteig |
| All times are GMT -8. The time now is 12:53 AM. |
