jld jld is offline
Rebuilding 915 transmission
I have replaced the diff and am working on setting the preload with shims under the bearings
I have made a bracket to attach to an output stub where I can use a torque wrench to read the resistance to turning
Does anyone have any information about what values I'm looking for?
Thanks...
Old 06-14-2025, 10:05 PM
Porsche Wiki
I think Pete covers this in part 5
Old 06-15-2025, 10:25 AM
jld jld is offline
I’m not familiar with him
Anymore information would be helpful
Old 06-15-2025, 11:14 AM
I just bought an '83 SC Cab and am snooping around for pattern failures and good advice. Thanx Pete. Nice site
Old 06-15-2025, 03:53 PM
jld jld is offline
Old 06-15-2025, 03:59 PM
jld jld is offline
Found it
Old 06-15-2025, 04:00 PM
Mark Salvetti's Avatar
Originally Posted by jld View Post
Found it
The preload is different depending on whether you are using SKF or FAG bearings, but I believe Pete's Wiki covers that.
Mark
1979 911SC Targa
Old 06-15-2025, 07:42 PM
jld jld is offline
Old 06-16-2025, 01:33 AM
jld jld is offline
P wiki helped but I need more information about the actual typical shim thickness on the top side. There's discussion about the lower two shims but nothing about the top and I'm starting from scratch there
So going the "conventional" way of measuring the gap between the case and a correctly placed cover plate, what would that measurement be ?
Happy Fourth ��
Old 07-03-2025, 09:25 PM
kevingross's Avatar
Happy Fourth ��
Not sure I fully understand your question. Typically, you install a pair of 2.50 mm shims, one on each side, along with the magnet carrier disc if your 915 is of that vintage. You then measure the freeplay and, as the WSM instructs, increase the S2 shimming to the freeplay plus recommended preload. Next, you measure the turning torque of the preloaded differential (without the pinion shaft installed) and adjust S2 to get the turning torque in the proper range.
A note of caution: if you take apart the transmission and find the original S1 shim is less than 2.50, don't start with a 2.50 S1 -- you'll bind the ring and pinion on assembly, which is not a good thing. I try to keep the initial S1 say 0.50 mm below where it ultimately will be and work my way up.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 07-07-2025, 07:17 PM
jld jld is offline
That was my question… starting with what, on the top side
Because I’m mating different diff ( disassembled ) to a new ( to me) trans
So I will start with a 2.0 and adjust from there
Thanks 👌
Old 07-07-2025, 08:15 PM
jld jld is offline
The other question was…
If I’m going the less technical way to set preload by measuring the gap between the, properly set top cover and the case, What would that measurement be??
Old 07-07-2025, 08:37 PM
shoooo32's Avatar
Are you installing a LSD? If you have the original diff you can just measure the two units and add or subtract shims based on those measurements. That usually puts you in tolerance for preload/backlash.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 07-08-2025, 07:15 AM
shoooo32's Avatar
-Tony
AchtungKraft #002
Old 07-08-2025, 07:19 AM
jld jld is offline
No LSD unfortunately
Different trans and different diff
Only point of reference is the two shims that were on the Speedo magnets side
Just bearing and race and no shims on the other side
Old 07-08-2025, 10:59 AM
kevingross's Avatar
The WSM calls for 0.3 to 0.4 mm of preload in a 915. So in theory you would want to have that much of a gap between the case and side cover. However, my experience has been that this method is not at all accurate and repeatable. It can be a good way to get an initial stab at preload. You'll generally find that this method does not reliably yield a turning torque value in the WSM's specified range. Turning torque is a much better, stable, repeatable indicator of preload.
Hope this helps.
Kevin
Old 07-08-2025, 05:02 PM
jld jld is offline
THANK YOU
This gives me a starting point 👍
I have extra shims to start with, plus an extra bearing to use should I need to put on and off the axle multiple times
Also made the setup for the torque wrench to use afterwards
Old 07-08-2025, 05:44 PM
jld jld is offline
Thank You for all the information.
Over loaded the shims, put it together and used the feeler gauge method with the cover plate.I was able to work backwards by removing shims until I came up with 0.45. I assembled everything and then did the torque test. Which put me at a Rolling setting of 37.
Old 07-21-2025, 12:26 PM
