Please help me identify this on my engine
I was working on my 1975 911S, with stock 2.7L, trying to identify and stop several small oil leaks. I found one leak on a bolt on the driver's side of the engine case. I saw that a previous owner had put two crush washers on the bolt and oil was weeping down the shaft of the bolt. I removed the nut and two washers. I replaced with a correct aluminum crush washer and nylon nut. As I tried to torque the bolt to 25Nm, I could not get to the correct torque. I found that as I tightened the nut, it was backing out the stud from the case. When I realized this, I stopped tightening it. I double nutted the stud and wound it back into the case. I did not remove the stud from the and it wound back in easily. I have no idea what this stud attaches to inside the engine and now I'm concerned that I've disconnected something. I decided not to run the engine until I seek advice here.
I have attached a photo of the engine and the stud/nut in question. Can someone please tell me what this stud attaches to inside the engine. I have not been able to torque this nut to the correct setting. What should I do? Jeff http://forums.pelicanparts.com/uploa...1742084799.jpg |
It's this stud. It holds the case halves together. I would leave it alone until time to split the case and rebuild the engine.
http://forums.pelicanparts.com/uploa...1742089064.jpg |
Some remedies here if you haven’t already read this:
http://forums.pelicanparts.com/porsche-911-technical-forum/1034758-what-s-nut-s-leaking-oil-my-engine.html |
Wrong Stud…..
Yelcab, The stud in question is the longer one in the back. Just behind the intermediate shaft and oil pump drive shaft shown in the picture. Tony |
One of the items I had fixed when I had my 2.7 case split. Case savers installed along with a number of other items. Cost is not for the faint of heart.
Thank you all for the replies. I will leave it alone.
| All times are GMT -8. The time now is 09:15 PM. |
