wrxnofx's Avatar
Screws the Hold Breather Tube Bracket onto Carrera Airbox
Even after 12 years of ownership, I'm still finding things missing from my car lol.
On my '87 Carrera, there are 2 large oil breather tubes and one small oil breather tube that go through a plastic bracket. That plastic bracket is mounted to the back of the airbox. My plastic bracket is just flapping in the breeze back there.
Went to order the screws to day from Porsche and they're no longer available. Anyone have 2 of these things they can drop in the mail to me? I'll happily pay.
P/N is N0139698, tapping screw, BZ 4.8x16mm.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 08-02-2025, 09:45 AM
'87 Targa
I don't have any. But, I believe 4.8mm Tapping Screws are a near match for #10 Pan Head Sheet Metal Screws. 16mm length is about 5/8" long.
Often carried in the little bags at the local hardware store.
Old 08-02-2025, 10:52 AM
WMichsen is correct…, takes some time and reading glasses for me to find misc. hardware at the big box or auto parts store.
You’ll be pressed to find 5/8” in #10 Stainless at the HomeDepot (EverBuilt brand) and Menards (Grip-Fast) where these are from only 1/2” & 3/4”. Menards has a metric selection but tiny packaging in packed drawers always is a mess of mixed up sizes.
Lowe’s (Hilman brand) has black coated #10 Interior Trim screws that I used on my door cards that may work, also found them at the local auto parts store.
Some Ace Hardware have individual s/s and chrome screws available but limited.
All these are about $2 for a package of 3 or 4.
Of course you don’t want to oversize and crack the plastic. I would try a #8 first to see how it fits in hole and thread wise which can be found in 5/8” length.
#10 x 1/2” would be advised as shorter is better and if #8 too loose… you can slip in a thin soft plastic shaving into the hole and tighten up a #8 screw.
Old 08-02-2025, 03:43 PM
wrxnofx's Avatar
Lightbulb
I ended up doing a search in the PET for the same thread pitch and length. Turns out the fasteners for the bellows are the same but with a hex head instead of a Phillips screw head.
P/N 900 187 018 02
Old 08-07-2025, 06:49 PM
917_Langheck's Avatar
If the PET spec quoted above is correct:
https://belmetric.com/m4-8-phillips-truss-self-tapping-screw-stainless-steel/?sku=SLH4.8X16SS
Other finishes are typically available as well.
Old 08-08-2025, 07:56 AM
