-   -   87 Carrera Rear Bumper Buffer (http://forums.pelicanparts.com/porsche-911-technical-forum/1175485-87-carrera-rear-bumper-buffer.html)
rwingnut1 03-22-2025 07:25 AM
1987 Carrera 3.2 - Tried to remove the rear bumper buffers (the big black blocks on the rear bumper). On the first nut I tried to remove, I broke the stud. Not enough time with the PB blaster, but I applied very little torque before it popped.
Are these studs replaceable? If they are replaceable, I'll go ahead and finish removing them and replace it. If not, I'll either leave it alone or find a replacement buffer. Any advice?
76FJ55 03-22-2025 07:43 AM
No, I don't believe they are replaceable, or at least not by factory design. there may be a way to modify it to accept a replacement if necessary. I don't know because I deleted mine in their entirety. Which side has the broken stud? I may have a good one that I removed from my car, but would need to check for which side if I still have it.
rwingnut1 03-22-2025 09:10 AM
Right hand side. Thanks for checking.
Racerbvd 03-22-2025 11:07 AM
Someone, either here or on facebook marketplace has a modified bumper like you and looking for and wants to go back to store
76FJ55 03-23-2025 05:16 AM
Sorry, but unfortunately the good one I have is for the Left.
rwingnut1 03-23-2025 04:18 PM
I appreciate you checking.
WMichelsen 03-23-2025 05:09 PM
I have a pair of driver quality ones that I posted FS under "Bumperettes". Just FYI.
