-   -   AC temp switch - help putting it back together (http://forums.pelicanparts.com/porsche-911-technical-forum/1175518-ac-temp-switch-help-putting-back-together.html)
Glenfield 03-22-2025 04:22 PM
Team,
Deleted my center console this winter while car is down. I had to disassemble the AC fan control switch to feed it through hole in original carpet. The switch broke when putting humpty dumpty back together again.
The offending switch is: 911 613 121 00.
Does anyone know where to locate version that has thermostat wire / disc located at top of housing?
Would love to avoid re-running a new thermostat wire to a new switch.
Glenfield 03-22-2025 04:23 PM
http://forums.pelicanparts.com/uploa...1742685762.jpg
Glenfield 03-22-2025 04:50 PM
To show my ignorance, it’s the capillary tube and bellow that I’d dearly love to avoid trifling with.
GH85Carrera 03-22-2025 07:13 PM
That capillary tube is fragile, and is filled with a gas. I would guess that if it came undone, you get to buy a new switch. They are a pain to get through the grommet, and back into the evaporator. You have to be very careful, and use a lube as you go put the grommet back in place.
Personally, I would contact Griffith's for his switch.
ccallana 03-22-2025 07:23 PM
I would also recommend Griffiths... But if you are set on an original... I just replaced mine.. you are welcome to it if you want it.
http://forums.pelicanparts.com/uploa...1742696596.jpg
Glenfield 03-24-2025 06:04 AM
Many thanks guys and also for the kind offer.
May actually be moot it would seem. I’m running electric A/C and after a bit more noodling, don’t believe it uses capillary tube. Showing my ignorance here but seems it’s better to be lucky than smart.
