SWB suspension questions & advice wanted
Has anyone changed from the early strut top to the later adjustable strut top on any early SWB car? if yes, other than the sheet metal and strut top, what parts are required?
Any front or rear SWB suspension recommendations would be great, I'm wanting a period correct hot rod that handles & brakes as well as possible, I'm not doing a concours restoration
Old 03-28-2025, 12:12 AM
Druepy's Avatar
I don't know the answer to your question for sure, but you should be able to swap the strut top without other changes. In my experience, the changes to the chassis across the SWB are pretty subtle. You could ask the question on early911sregistry.org to increase the eyes on the question. Another thing you can do is try to figure out what modifications the cars in the 2.0L Cup Series are running.
Like this 65 that has the later strut tops.
https://www.maxted-page.com/car-for-sale/1965-porsche-911-2-0l-cup
Then this one shows the old tower.
https://www.racecarsdirect.com/Advert/Details/127717/1965-911-20-race-car-fia-htp-20-cup
I am a fan of the 2.0L cup series and these cars have been an inspiration for my own car. Sounds like it could be a good guide for your build as well.
1968 911 S
Searching for transmission # 2281852
Old 03-28-2025, 06:15 AM
Druepy's Avatar
Here is Paul Abbott's guide for setting up your SWB 911
https://www.early911sregistry.org/forums/showthread.php?175333-SWB-engine-and-suspension-upgrades
1968 911 S
Old 03-28-2025, 06:24 AM
Changing the strut top to the later style limits the amount of caster you can get. Is there a reason you want to switch that part specifically? I just finished swapping my entire front suspension for a later setup with ER bushings, turbo tie rods, aluminum cross member, etc. and reused the early tops just fine. Fit perfectly with the later struts.
Sent from my SM-S931U using Tapatalk
Old 03-28-2025, 07:49 AM
