-   -   Window frame rivet (http://forums.pelicanparts.com/porsche-911-technical-forum/1175815-window-frame-rivet.html)
D@vid 03-31-2025 02:46 AM
Window frame rivet
Hi guys,
At the moment, I'm restoring the window frames of my 1973 911T.
I had to remove all the steel parts prior to anodizing, and now I'm trying to put everything back together again.
The main question I have is: what kind of rivet do I need to use to secure the steel bracket to the frame? Can I use a regular aluminum pop rivet, or is there a special rivet I need?
Kind regards,
D@vid
http://forums.pelicanparts.com/uploa...1743414217.JPG
PeteKz 03-31-2025 11:01 PM
I don't know for sure what rivets were original, but that looks like steel. I would not use an aluminum pop rivet. I doubt it will be strong enough. How about using a nut and bolt of the correct size?
WMichelsen 04-01-2025 08:40 AM
*Warning:* Ignorant thought from 1987 Targa owner!
Would they use the copper rivets from the Targa wing window cap? PN: 900.056.003.20
http://forums.pelicanparts.com/uploa...1743521945.jpg
D@vid 04-02-2025 12:01 AM
Thanks guys, I will explore both options. However I don't really know what tools I need for the copper rivets. Also copper may not be strong enough.
Kind regards,
Mark Salvetti 04-03-2025 11:28 PM
Kind regards,
I was thinking about those copper Targa rivets as well. Here is a great thread that shows how to install them for the Targa window stop.
https://forums.pelicanparts.com/porsche-911-technical-forum/566914-question-asked-but-never-answered-how-do-i-install-new-targa-window-stops.html
Mark
D@vid 04-07-2025 01:53 AM
Thanks Mark,
That might work. Will look into that.
Again, thanks for your input guys.
Kind regards,
