-   -   Can’t rotate the engine manually (http://forums.pelicanparts.com/porsche-911-technical-forum/1175854-can-t-rotate-engine-manually.html)
bose213 03-31-2025 03:52 PM
Hello,
I have a problem when trying to turn the engine manually using a wrench on the cooling fan. The belt that connects the fan to the engine keeps slipping, even though it is properly tightened. Could this be related to the timing chain tension?
If it helps, my car has a Sportomatic transmission.
Porsche 911sc 1979 3.0L.
Thanks.
walt 03-31-2025 04:24 PM
You need to press on the belt to increase tension. Just one finger on one side will usually do it.
2svnhvn 03-31-2025 04:43 PM
Also you can rotate it by using a wrench directly on the crank pulley
OldSpool87 03-31-2025 05:07 PM
Press belt at midway point between pullies
tobluforu 03-31-2025 06:13 PM
Put a wrench on the crank bolt, it's a tight fit, can you rotate motor.
A930Rocket 03-31-2025 06:30 PM
Do what I did. Drill a hole to reach the crank shaft bolt!
http://forums.pelicanparts.com/uploa...1743470841.jpg
Bill Douglas 03-31-2025 09:06 PM
A ring wrench fits down the gap to the nut on the end of the crankshaft.
I had a crashed donor car in a shed for 8 years and every month or so I'd rotate the engine 1/4 of a turn using this method.
Alan L 03-31-2025 10:50 PM
You can tension the RHS of the belt and that should work - finger tight as others say. But you can't hold it against that on the LHS.
Taking the plugs out will help. Even most of them if some put you off.
Yes Bill - I know that car well - or bits of it.
Alan
garment 04-01-2025 07:42 AM
Wut
David Inc. 04-01-2025 08:57 AM
Too early for April 1st!
pmax 04-01-2025 11:11 AM
^^^ Manual starter
Originally Posted by bose213 (Post 12438529)
Hello,
Thanks.
Could be related to this ...
http://forums.pelicanparts.com/porsche-911-technical-forum/1175855-knocking-sound-low-rpm-video-attached.html
A930Rocket 04-01-2025 08:03 PM
I forget why I drilled a hole in the license plate and bumper to access the crankshaft bolt, but I did it for some reason
smadsen 04-01-2025 08:55 PM
I'm told never turn the motor backward. Can't remember why. Timing chains I think & the tension thereof.
dictoresno 04-01-2025 09:49 PM
yea you will throw off the tension on the timing chain and possibly skip teeth, throwing off the timing.
