Engine Bay Refresh
This group was helpful in convincing me to keep my 3.2 rather than spend a bunch of money to replace it. Having said that, there is a suggestion to return the heater system to the one that came in my 69 tub. Does anyone have a picture of a 1969 911 engine bay showing the tin and other components? As noted, I have a 3.2 installed. Have attache a picture of the current condition. I am thinking the 3.2 heater, etc is really not being used.
Thank youhttp://forums.pelicanparts.com/uploa...1743700478.jpg |
I have an SSI exhaust system installed on my '88 with the 3.2L engine. Not wanting to eliminate the engine mounted heater blower, here is what I did:
http://forums.pelicanparts.com/porsche-911-technical-forum/1074853-ssi-exhaust-heater-system-workaround.html If you are running this type of exhaust system, you may want to consider this. Heat output is amazing. |
I deleted the electric blower on my '88 by using a fan duct from an earlier model to get the look you're after and retain the heat function using the engine fan like the '69 did originally.
Like this except I used a black hose: http://forums.pelicanparts.com/uploa...1259200399.jpg http://forums.pelicanparts.com/porsche-911-technical-forum/513136-87-carrera-heater-blower-s-delete-question.html |
Our host has the key part: https://www.pelicanparts.com/More_Info/93010632101V2PH.htm |
thank you all for your suggestions. I will check tomorrow since there may be a switch under my dash put there by a previous owner that runs fans. Not sure why or what. In the meanwhile th link suggested above does not work.
That's why the switch is there in yours. Needs a relay as well if not already there. |
Maybe, but it is clearly an aftermarket tiny toggle.
https://www.youtube.com/watch?v=MXuTpWfD5vQ |
Thank you for that link. Apologies for the tardiness in my thanks, been distracted by recent events |
| All times are GMT -8. The time now is 07:59 PM. |
