Dkennel's Avatar
courtesy lights no power
Gave the car a good cleaning today, just as I am almost finished I start messing with the courtesy lights, get always confused with the settings. I work on the drivers side light, all of a sudden no more light regardless of switch setting, no constant, no door switch, I wiggle the door switch, no fix, check the passenger courtesy light, no power either??? check my fuse block, #4 is o.k. and my clock works, I pull the driver door light, wiggle contacts, no luck, seems both lights get no power, but my fuse is ok, I am thinking poor contact somewhere. Any ideas? suggestions? anybody same problem in past? since it is both lights it should be central close to the fuse block?
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 10-09-2011, 03:30 PM
pete3799's Avatar
^^+1
Check for power on both sides of the fuse.
Pete
79 911SC RoW
Old 10-09-2011, 04:00 PM
Dkennel's Avatar
the circuit also supplies power to the clock, and my clock is just working fine, fuse looks fine, i'll check for power
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 10-09-2011, 08:15 PM
Dkennel's Avatar
yup got power on both sides of the fuse, there is constant power to that circuit, but lights do not work in any of the switch positions, and that's on both sides....
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 10-09-2011, 08:21 PM
Dkennel's Avatar
radio works, glove compartment light works, luggage light, and clock works, but both interior lights do not....how are the connection wires routed and where could the current be interrupted to both sides?
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 10-09-2011, 08:38 PM
Dkennel's Avatar
...and the lights should work on constant position...I am baffled by this, thought for sure I somehow had blown the fuse
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 10-09-2011, 09:07 PM
Dkennel's Avatar
just pulled the driver side interior light out, I have no power on either the constant power or the door switch cable...there is good power on the fuse block on both sides of the fuse..light worked fine this morning...I don't understand
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 10-09-2011, 09:46 PM
D911SC's Avatar
I'm not sure if this applies to an 87, but on my 83 the power and gnd are connected near the luggage compartment light. There are a couple of wires with simple spade type connectors there. These feed the courtesy lights. If these wires are not connected everything else will work but the courtesy lights.
I couldn't work it out from the above wiring diagram but the one in my Bentley pointed me to the luggage compartment light. You might find it easier to trace the switch wire from the door switch. Mine went from the door panel up through the bulk head and then connected to to the wires feeding the luggage light as mentioned.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 10-09-2011, 10:36 PM
D911SC's Avatar
PS. If it's like an 83 make sure you are troubleshooting the light that has two wires coming into one end on the light fitting. This is the one that then feeds the other light (right hand side on my RHD car).
Old 10-09-2011, 10:43 PM
Dkennel's Avatar
thanks d911sc, I couldn't find a wiring diagram in my Bentley manual that shows the courtesy/interior lights, I'll check the luggage light and the right side indoor light, I know I have power to the luggage light, hopefully I can find an answer there.
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 10-10-2011, 06:23 AM
Dkennel's Avatar
Porsche 911 Wiring Harnesses FRONT Luggage Compartment Interior Lights Sunroof Parts
found this for the wiring harness, does appear that the interior lights for the coupe plug in close to the luggage light...
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 10-10-2011, 08:55 AM
Ova Day
msterling's Avatar
Great info! I have the same problem with my 88 911 Cab. I rarely need those lights but they do not work. I'll be taking a look at this.
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 10-10-2011, 09:15 AM
Brorag
Brorag's Avatar
Just finished rewiring that circuit.
I've got the 87 cab--the light is mounted over the windshield.
Try the easy stuff first.
Don't know if we're talking about the same light, or if you have the coupe and the light is different, but:
the light unit itself was switched with 3 positions; on/off/on with door open. The door switch provides a ground to the light in one of those positons.
Do you have that fixture? If so, it may be in the off positon.
Old 10-12-2011, 07:55 PM
Ova Day
msterling's Avatar
Yup, I found that the whole light (above the mirror) swivels to actuate a 3-position switch. Mine was in the OFF position. Duh! Now that I know how to work it; it works!
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 10-13-2011, 05:51 AM
Dkennel's Avatar
87 coupe, similar light, but one over each door.
Here is my update, wiggled connectors close to the luggage light and I have power back to the door lights, but so far only in the constant on position, still no light in the door position, not on either side and not with either door switch, doubt it is the door switches, will need to research the connectors under the hood more, does anybody know which connectors go to the interior lights? I'll take pictures next time I get under there.
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 10-13-2011, 08:51 AM
Send a message via Skype™ to Porboynz
On a 1972 (maybe the same, why change?) the same fused power feed operates the interior lights for the manual on/off at the light fitting and the door operated position. When using the manual "on'' position the path to earth for the bulb is through the light fittings spring mounting clip to the bodywork. Sometimes a fold of hood cloth can get in the way or surface corrosion needs cleaning. When in the door switch operated position then the door pillar switches are the path to earth. So to test you can pop the rubber off and unscrew a switch. You should be able to measure the 12v on the wire. Maybe when you were messing with the light fittings you swapped the wires or dislodged the door switch wires?
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 10-15-2011, 11:18 PM
D911SC's Avatar
The door switch goes to the luggage compartment connections and then to the light. I would disconnect the connectors and clean with emery paper. You might find it works after doing this.
It might be worth cleaning the connections at the light itself. Maybe this is stopping the circuit being completed by the door switch.
If it's still not working you could troubleshoot by getting a spare wire and grounding at each connection to see where the issue is (ie. ground at the light while it's in the 'door open' position or ground at the luggage compartment connection, etc)
Old 10-16-2011, 02:14 AM
proporsche's Avatar
Hello Dietmar
Try this.Your front trunk light is in the same el.system as is interior lights.Under the front hood switch (follow the wire) is power supply and grounds to these lights.There you need to find a connector which is only one way power with a resistor inside.It is about 10cm long try to find this and measure that connector if the power goes trough it .That could your interior lights problem.Also check ground connection there(under trunk switch behind the hood shock)
i hope this will help you
any Q. my mail is proporsche@yahoo.com
proporsche
Old 10-16-2011, 05:56 AM
Dkennel's Avatar
Finally resolved this issue, as so often it was two separate issues. As previously stated I must have had a poor connection near the luggage light, after wiggling that connector lights came back on, at some point in my process of checking things passenger door switch activated lights again, but nothing on driver side....so I pulled the door switch on driver side to find that the ground wire had broke off. Managed to fish the wire through the switch hole and re-soldered the ground wire. All works fine now as intended! Case closed, thanks everybody.
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 11-19-2011, 10:44 PM
I know this is an old thread but this is the exact same scenario I am having with my interior lights. Does anyone know the exact location of the interior light wire connection near the trunk light, or have a picture of the connection?
Old 01-25-2025, 11:30 PM
