Spring(s)
After putting engine/trans back in my 76. 2,7 l car I'm left with one spring to mount on the speed/throttle housing.There's a long and short piece on that spring.I can't imagine how she should be attached( don't even know if it's the wright spring)
When I look at older posts here on pelican I see pictures with 2 springs ( one vertical and one horizontal). On the intake runners I don't find a spot with a tiny little hole in it. Thanks |
https://forums.pelicanparts.com/porsche-911-technical-forum/794868-need-picture-throttle-bracket-engine-bay.html
Possible help |
Strange,when I look at rose passion i see only one ,the one I have with a short and long side
Can someone tell me the numbers of these springs? |
The vertical tension spring is 930 110 497 00.
The other tension spring with one long end and one short end is 911 110 165 02. These are the Porsche part numbers from the PET manual available online. Rose Passion have their own numbers. You can match them to Porsche part numbers by looking into their product page metadata (in the page's source code). That's how I always do it to make sure I'm looking at the right part. |
Ah ok, merci beaucoup.
| All times are GMT -8. The time now is 07:31 AM. |
