frankc's Avatar
Ultrasonic Cleaning Weber Carburetors
Hello,
I'm rebuilding a set of Weber 40 IDFs, and I've read mixed opinions on whether cleaning the carb body in an ultrasonic cleaner is safe for the sealed bearings on the throttle shaft (note these are IDF, not IDA).
Do folks remove the bearing seals first and clean out the grease before placing the carbs in the ultrasonic, and then re-pack them with grease and re-install the seals afterwards? Or is it better to avoid submerging the bearings?
Thanks,
Frank
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 04-08-2025, 04:04 PM
The 9 Store
An ultrasonic tank will often pop out the plugs in the body of the carbs.
All used parts sold as is.
Old 04-08-2025, 07:20 PM
frankc's Avatar
When I was searching for information on this topic, I did read in some forum where someone reported some plugs were loose after ultrasonic cleaning. Then again, I've read about plugs falling out while people were just driving down the road - no ultrasonic cleaning involved.
I'll keep searching to see if I can find more on the plug issue, or ask around in some of the other forums. If it was a common problem, it seems like there would be more reports of it happening given the number of people/shops who use ultrasonic cleaners for carbs. Perhaps they always stake the plugs afterwards as a precautionary measure.
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 04-08-2025, 09:06 PM
The 9 Store
We have a 20 gallon ultrasound tank and I can say for sure it happens.
Old 04-09-2025, 04:40 AM
What’s the big deal with the plugs, they should be removed anyway especially if the carbs are crusty.
You can replace them with .177 caliber pellets.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 04-09-2025, 05:15 AM
Just caught the IDF part, not sure if the plugs are the same size as on IDA3c et but if they are pellets work fine.
Old 04-09-2025, 05:27 AM
frankc's Avatar
@mepstein,
Thanks for confirming. If I end up going the ultrasonic route (likely), I'll definitely check the plugs afterwards.
When I got the car (recently), I noticed that the air filters were installed incorrectly by the PO. As a result, the Idle circuit was open to unfiltered air and is completely clogged on one carb. Gumout is not clearing it, hence the ultrasonic cleaner.
@Dpmulvan,
Good to know about using pellets for plugs. I'll measure the IDF plugs to see if they are the same size as the plugs on my IDAs.
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 04-09-2025, 03:25 PM
Registered Minimalist
75 911s's Avatar
All these old carbs, the plugs have to be drilled out anyway to check those hidden passages for gunk. They are highly susceptible to being plugged.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 04-09-2025, 03:49 PM
Originally Posted by frankc View Post
@mepstein,
@Dpmulvan,
Ultrasonic especially the cheap Chinese ones are not going to unplug the circuits, you’ll have to do it manually with tiny drill bits.
Old 04-10-2025, 05:51 AM
