digital sync tool
I've been seeing some motorcycle mechanics on youtube use this tool and they seem to like it, wondering if it could be useful to us
has anyone tried this already? https://thedigisync.com/
Instagram.com/timofthevalley |
Rutager West 1977 911S Targa Chocolate Brown |
Looks very interesting. I wonder if/how it would work on Webers or Zenith carbs?
Subscribed. |
I bought it to do my PMO ITBs. Because I use the vacuum ports to tell the engine how much fuel to supply, removing the lines to hook up the tool will make my ECU think that there is no vacuum and it won’t run right.
I was thinking that maybe I could use a hand vacuum pump to make the computer think it’s getting a signal and then I can hook up the Digisync to the 6 ports and adjust. What do you guys think of the plan? If it should work, I could give it a try in the garage soon and report back.
Why not use a t fitting so your ecu can get a real reading
Because all 6 plenums sum together to feed the computer and you would get an average reading of all of them on the tool instead of being able to get them balanced.
It could be possible to leave a couple hooked to the computer, sync the others and then switch and sync the rest; not sure if that would be as accurate though. The other option, could be to do do a throttle position sensor table instead of vacuum so the engine could run while doing the sync.
It’s been a long time since I owned a car with carbs, so do they have a vacuum port on each cylinder and does it get hooked up to something during operation?
Full Send Society
It seems overly complicated but you could split the hose from each throttle body and then send one hose to the device and one to the common plenum to the ECU…
Alternatively, yes switching to TPS for fueling would solve that problem.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Wouldn’t that effectively connect all of the vacuum signals together, so you would get the same reading on all bodies even if they were different individually? I may try my vacuum pump on the MAP and then hook up each port to the tool individually. I’m about to drop the engine for a cam sensor and new ECU, so doing the test now would really just be to help the community decide if the tool is valuable. If it works, I can can lend it to you once you get your engine back running. Rutager
Full Send Society
Hmm now that I think about it I think you’re right.
Perhaps just switching to tps for this procedure is best.
maybe look at these
https://raytechautomotive.com/products/synchroking-carb-throttle-body-balancer?variant=39568458186945
Always learning. www.aircooledporsches.com.au |
PMO Carbs
Arrows point to possible ports to screw in the vacuum adapters ![]() Looks interesting. Good luck,
Don "Gordo" Gordon '83 911SC Targa |
Manifolds can also be drilled and tapped for fittings
Are you running TPS for your fueling tables? If MAP, how do you keep the engine running without the proper vacuum signals?
A while ago I tested the electronic balancer (not digital though) from my BMW motorcycle engine. If you just connect it to the vacuum ports of both banks, you get some average values which are fluctuating quite a bit. Probably can be used for a rough left/right synchronization, but no replacement for a good old airflow tool. Certainly better to connect all 6 throttles, but not sure if it is worth the effort.
Regards, Guenter 73.5 911T, mod |
Too Much Tool?
I agree - appears a rather involved process for 6 carbs when the flow/synchrometer is considered good enough by most. I would be interested in monitoring and recording that sort of data while driving though, but again $$$$ vs synchrometer.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
