Repair of auto heat control
Does anyone know who repairs the auto heat control that sits between the front seats.
The unit with a dial that started a round mid 70’s.
Old 04-09-2025, 06:20 AM
Found this, check here; https://www.systemsc.com/Parts.htm
Dave
Old 04-09-2025, 06:24 AM
cpa cpa is online now
Contact Kris Rose, mailto:JamesDean59@gmail.com
He is a forum member, quality electronics repair, reasonable price.
Old 04-09-2025, 10:18 AM
stevie 77 930's Avatar
I shipped mine to Tore Bergvill in Norway
https://www.bergvillfx.com/products/911-autoheat
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 04-09-2025, 01:36 PM
Did you change the nylon connectors under-the right side access plate?
Need to remove the seat to access the rod and connectors
Suggest you replace the flapper heat box cable covers as they fill with grime and make the automation work too hard.
Bruce
Old 04-09-2025, 07:14 PM
Thanks guys. The unit seems to be dead, and it is getting power.
Old 04-10-2025, 04:49 AM
What car? I mean what model year?
There are basically two versions of the electronic card (PCB) inside. Both work the same way but use different components. Send the unit to systemsc, they know how to deal with it.
Gilles
RoW 88 Carrera coupé
Old 04-10-2025, 06:19 AM
77 3.0 Carrera
Old 04-10-2025, 06:47 AM
OK so it must be the earlier generation with BD175 (or 131 or 235) / BD176 (or 132) transistors in a H bridge. One of them can pop when the mechanism is binding or a limit switch does not open when it should.
Gilles
Old 04-10-2025, 08:34 AM
Why a ship to a faraway location, when a local source is here in SoCal; www.systemsc.com ?
Dave
Old 04-10-2025, 09:06 AM
There are many problems that occur with unit besides "power";
1. disconnected temp sensors - 3
2. damaged micro-switches
3. stuck motor armature
4. failed motor control board
5. stuck heater flaps
6. damaged potentiometer, and or knob setting
Dave
Old 04-10-2025, 09:15 AM
rokemester's Avatar
There are some excellent threads on this topic. I swapped my box for a used unit, replaced sensors based on found intelligence here.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 04-10-2025, 07:40 PM
Sent to LORAN, thanks for all the good info.
Old 04-11-2025, 05:52 AM
Been here a while
you mean "Dave" ??
looking for 1972 911t motor XR584, S/N 6121622
Old 04-11-2025, 07:55 AM
Systems Consulting
Old 04-11-2025, 02:03 PM
