-   -   Spark plugs for a high Comp. twin plug race motor? (http://forums.pelicanparts.com/porsche-911-technical-forum/1176287-spark-plugs-high-comp-twin-plug-race-motor.html)
Geneman 04-10-2025 03:23 PM
Hi Peeps. I just had a motor rebuild. All the race goodies. Bill Condina at Xtreme did the heads and, of course removed the plugs.. so I do not know what to run and need to order now. Any suggestions.... ( trying to get this operational for the PCA club race at Lime Rock in 2 weeks..) reasonable cams, MSD ignition, 50mm PMOs, always race gas.
Thanks very much. Frank. SmileWavy
gled49 04-10-2025 05:08 PM
Single or twin plug? 12 or 14mm plugs or both? Please preface request with some basic info.
Geneman 04-10-2025 06:10 PM
Thanks gled. twin plug as indicated in title, I think they were either 3.0 or 3.2 heads to begin with. not sure if 12 or 14 mm but this was not altered from stock by the hand guy at xtreme
head guy
snbush67 04-10-2025 09:38 PM
The stock holes upper are 14mm, the bottom hole could be 12 or 14mm. It’s likely if Bill did the heads that the bottom holes are 12mm but you have to check.
NGK BPR8ES are 14mm
NGK D8EA 2120 are 12mm
http://forums.pelicanparts.com/uploa...1744346083.jpg
Shane
winders 04-10-2025 09:50 PM
I used Brisk silver racing plugs in my engine with Xtreme heads. Both holes were 12mm so I used Brisk BR12S plugs.
proporsche 04-11-2025 04:13 AM
i also use Brisk -since they are local Bohemian company with an excellent reputation;-)
Ivan
Geneman 04-11-2025 05:34 PM
thanks everyone. great stuff
