-   -   Backup Switch Wiring (http://forums.pelicanparts.com/porsche-911-technical-forum/1176372-backup-switch-wiring.html)
Crow911 04-12-2025 05:05 PM
Dropped engine for clutch replacement (upgrade due to slipping clutch at WOT .7 bar boost) and when putting everything back together, discovered one of the push pin connectors for the reverse light switch broke off the wire. Search internet and nobody has any repair kit or listing for wiring harness. Anybody out there ever repaired the push connectors?
Magyar Kiwi 04-12-2025 05:31 PM
Hi
It is a bullet connector.
You may be able to repair the wiring harness by salvaging the original "bullet".
Drill thru the "Bullet" and then solder the wire in place.
Or
P/N 999-652-102-10 From Pelican
Cheers
Crow911 04-12-2025 05:50 PM
10-4…just ordered.
timmy2 04-12-2025 08:27 PM
Newer style is 91161290701
They solder on the end of the wire. Not through as the earlier ones did.
