Headlight washer pump
The relay clicks, but no shpritz (as they say in Germany). Bad pump? Can it be fixed? If not, does our host sell new ones?
Thanks.
1984 Targa |
I don't have a lite washer. so only a little help/maybe.
If my shield washer pump wasn't correctly working I'd lift up the wiper arms. turn on the washer and see if the pump is working, and that the intake is getting fluid.. if pump NG, then I'd remove stock wires and do a test jump. maybe a switch. maybe remove stock discharge hoses to test, etc.. then maybe have to test/clean discharge nozzle or a check valve.. it's a simple system. that's all I got...........Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks, Ron. BTW, you have mail on that other subject.
Scott
1984 Targa |
