79SC RPM Search during warmup
I have a 79 911SC and I am chasing an issue on warmup. I have had the car for about 8 months and I am new to CIS so just looking for what might be the next logical step.
The car starts without issue and idles at around 1100 RPM. It slowly starts to come down, after a minute or two the idle starts to surge. As the car warms the RPM's settle at approx 800 -900 RPM and the surge is gone. I have done a smoke test and have only found one small leak which appears to be coming from the back of the airbox. I checked fuel pressures and found. WUR # 0-438-140-089 System Pressure 4.8B @ 31C Cold Control Pressure 1.6B 10 minute test with the WUR Connected 1M 2.2B 2M 2.4B 3M 2.5B The pressure does not increase after 4M Residual Pressure @0 = 2.9 @15M=1.6 @30M=1.35 Thanks for any advice. Last edited by Jaymanbikes13; 04-07-2025 at 08:02 AM.. |
PCA Member since 1988
The pressures look okay. Check your timing. Too much advance often causes unstable idle and bucking in gear at low RPM.
How often do you drive it hard? Also try pouring a bottle of Chevron Techron Concentrate into the tank, then go drive the piss out of it. Report back what you find.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thanks |
It may be the diaphragm is working but the advance mechanism is frozen.
It may be the idle mix is slightly out. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Alan makes a good point. If the vacuum advance isn't working, or the distributor is stuck internally, then fix those first. Refresh my memory--does your dizzy have a vacuum can with TWO nipples (one for advance and one for retard at idle/closed throttle) or only one?
That's the "good" dizzy. Make sure it's advancing correctly.
I had to completely remove the pickup coil/advance plate and get it working again as the unit on my '78 was completely frozen. I was able to clamp the base in a vise with padded jaws and apply penetrating oil to the center hub and bearing. I was finally able to get the top half to start turning by hand but it was very stiff. After about 30 minutes of more penetrating oil and exercise it moved freely. I think a lack of previous owners adding a drop or two of oil to the hub bearing once a year allowed the grease inside to harden. Night and day difference in performance with a working vacuum advance.
1990 928 S4 1998 Boxster 1978 911SC coupe |
