993 C4S 1st gear engagement issue
My 1996 C4S got a new factory porsche clutch installed.
However, it now dosnt like going into first gear unless you are almost to a stop, otherwise it will grind. ( before i could downshift into first on the way to a stop light while rolling with no issue) Now, we reused the flywheel. Would that be the issue?
WANTED: 1967 Transmission #103586 1967 Transmission #200082 1969 Engine#6195922 1969 transmission#7194313 1969 transmission#7195495 |
PCA Member since 1988
I'm not a 993 guru, but it sounds like the clutch is dragging/not fully released.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Since work was recently done, try re-bleeding the clutch slave to eliminate a hydraulic issue.
When you say the flywheel was reused was it machined? I'm pretty sure that's a DM flywheel and it shouldn't be machined.
'87 911 GP White "casper" '79 930 Copper Brown Metallic "beast" '93 968 Amazon Green Met "moby" '97 Esprit V8 "flat eric" '97 993 Speed Yellow "tbd" |
Every other gear is fine. Only 1st wants to be almost stopped to engage.
Thanks, perhaps rebleed might work. Flywheel wasnt machined. But also not replaced.
I know, but it seems that first gear is the one that has the most problems when there is slight clutch drag.
Banned
A worn or improperly resurfaced flywheel can cause uneven engagement, making shifting into first gear difficult. It could also be a sign that the clutch isn't fully disengaging. I’d suggest double-checking the clutch adjustment and making sure the flywheel surface was properly prepared. If that all looks good, it might be worth revisiting the installation to ensure everything’s aligned correctly.
