rennline billet fan fitment issue
hello. does anyone have a solve for the rennline billet fan shroud 6mm holes? my alt uses 5mm studs to locate, and the concern is that 1 mm difference may/will eventually create a centering issue... which is unfortunately enough to cause interference....
Old 04-16-2025, 08:00 PM
The alternator body centers iit in the housing, not the studs. Good tight fit.
206 637 4071
Old 04-16-2025, 10:16 PM
follow up for those that may run into the same issue -- just got word today - rennline has spring sleeve adapters that press into the holes on the fan housing/ shroud, taking up that extra millimeter.
Old 04-17-2025, 04:28 PM
