How loud is my fuel pump (with vid)
https://www.youtube.com/shorts/Yh3md6YVwzA
I'm worried about the sound my fuel pump is making. It's been rather loud as long as I remember, but now the wine 'beats' in and out from the front pump. (you can hear in the beginning of the video) Is it near death? Reading the forums, I still need to try: 1) Test current draw (what's the target amperage?) 2) Test fuel pressure (2 bar when both running, 4 bar when just the front one is running, if i remember correctly) 3) Check for debris in the tank screen. (anyone have good links on how to do this?) 4) Replace fuel filter? (what's the test for this?) I'm worried about the pump that is in the front. Anecdotally, I've had hesitation after long 0-60mph+ pull. Hints to me at fuel starvation, but not sure. If that noise is normal, do any of you run an aftermarket pump that is less loud? I have a 1986 930, but i assume it's the same stuff on most CIS 911s.
88 BMW 325 86 911 Turbo |
What I think: the fuel pump is only supposed to run in the start position and, of course, when the engine is running.
Wrong……….
Did you have two little wires connected on the fuse panel? From what number to what number and why?
Lucille my ‘85 guards red 3.2 |
Oh, yes. I intentionally bridged the relays so that I could hear them by themselves, confirming that the noise I didn't like was indeed the fuel pump. (and which one).
FP Relay Wiring………..
What I know is what I said before; my fuel pump is only running in the start position and when the engine is running. And this has been so for the last 18 years (with the same pump)
What avenbut said is the FP runs only when cranking and once the engine has started. And this is correct. It has always been so since 1976, when this safety feature was introduced on CIS cars. Goal is to cut power to the FP in case the engine stalls, like in an accident, for instance. There's a good illustrated and animated diagram here from AndrewCologne's own web site.
Gilles RoW 88 Carrera coupé |
This is great guys.
Anyone want to tell me about the pump noise? Does yours sound like this? Or is it quiet?
Still here
Try https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/
Not familiar with the 930's fuel pump setup, I won't be surprised if it differs. In general, it's hard to tell what's normal volume, exacerbated by the fact that the vid's taken in an enclosed room. |
I’ve noticed that when you’re in the car with the doors closed, the noise is practically negligible. And when your engine is running, you probably don’t hear anything at all (inside the car).
I have owned a 79 911SC for about 8 months and my fuel pump is very loud, sometimes I can hear it over my radio. I purchased a replacement thinking it is on its last leg. The car runs great so I am a bit apprehensive about swapping it out.
Informally, it sounds like some of us have louder pumps than others... 930 or 911, yeah. It's a different part number, but the fuel system has the same architecture. It's probably just a difference of max flowrate and/or pressure. But what do i know.
My fuel pump only sounded that loud before it died. Replaced it two years ago and haven’t heard a sound since (other than when it first primes as I turn the key). I seem to be having an issue with mine even turning on at the moment though, so what do I know. For sure yours is loud. Might be the vibration of it working is resonating against some metal. Might just need a shift in its position. Might need a new fuel pump. Hard to tell. Try repositioning first and if still making the noise, swap it.
Mine screamed like a banshee all of a sudden. Cause: Ran out of gas, low fuel level. Obviously struggled to suck up any fuel, when it did the screech went away until I came to a stop.
Found my fuel gauge/sender was defective, inaccurate and registered under 1/4 full. Replaced and no further noise, still won’t trust the gauge. |
Amperage test or front pump comes out to 6.6 amps. Normal?
Also, here's another longer video of my pump's sound. https://www.youtube.com/shorts/gz5xq0uKslg It used to run an more 'even' hum. Now you hear it 'gyrate', for lack of a better word.
| Tags |
| fuel pump 930 |
