Need to buy turn signal bulbs locally.
I need to buy front and rear turn signal bulbs for my 81 930. Is there an Autozone equivalent or something I can buy locally? Would be open to LED's as well as long as they are directly swappable.
1156 (single filament) or 1157 (dual filament) should do the trick. They can be an any FLAPS.
Those protrusions ensure the bulb is installed only one way so the brake and taillight filaments are in the right location in the socket. Plus 1156 bulbs are single filament while the 57's are dual. A 1156 in a dual socket may light up but not as a tail and brake light function.
If you look in the sockets you will see either 1 (takes a 1156) or 2 (takes a 1157) metal strips that contact the terminal(s) in the bulb base. Sometimes they get flat. You can gently pull them up to improve contact. |
I’m surprised that a auto parts store doesn’t sell them. Here is the euro numbers.
http://forums.pelicanparts.com/uploa...1745961725.png |
Take a closer look inside the sockets and make sure they’re not damaged.
Notably are the offset of the bulb base posts which if not positioned correctly can cause damage. Btw, I recently replaced my Ft/Rr turn signals and dash signal indicators to LEDs from Carmagic and had no problems although needed proper flasher so dash directional indicator operated correctly. Owners manual calls for #1073 front and #1034 rear. Hella, Osram, Sylvanis, Phillips, GE all have equivalent number of basically the 1156 & 1157. Here are my old bulbs Ft/Rr I swapped out for LEDs. http://forums.pelicanparts.com/uploa...1745966547.jpg http://forums.pelicanparts.com/uploa...1745966572.jpg Another bulb cross reference chart: http://forums.pelicanparts.com/uploa...1745966596.jpg |
| All times are GMT -8. The time now is 04:40 PM. |
