-   -   Replace or reuse, 38mm stainless early rear caliper piston (http://forums.pelicanparts.com/porsche-911-technical-forum/1176999-replace-reuse-38mm-stainless-early-rear-caliper-piston.html)
72doug2,2S 04-28-2025 01:24 PM
Replace?http://forums.pelicanparts.com/uploa...1745875408.jpg
http://forums.pelicanparts.com/uploa...1745875425.jpg
76FJ55 04-28-2025 01:34 PM
that looks like a chrome plated piston to me, not stainless.
72doug2,2S 04-28-2025 04:12 PM
Perhaps, although I don't see an option for that on our host site
nickelplated5s 04-28-2025 04:53 PM
You have it apart so just put a new one in.
Magyar Kiwi 04-28-2025 08:10 PM
Hi
The original OEM pistons are chrome plated steel and prone to rusting..
The replacement non OEM ones these days are often made from stainless steel, removing the rusting problem.
If you choose to replace, probably best to replace both pistons in the caliper.
Cheers
72doug2,2S 04-29-2025 03:24 AM
These little guys were such a pain to remove. The air compressor barely moved one side.
I bought a cheap $77 Chinese Vervor diesel pressure tester and mated up a 12mm connection (to a rubber hose i found on a Mercedes repair site) to the caliper. I fixed the diesel leaks by applying a few wraps of plummer's tape to the inside nipples (cleaning the holes for flow) after connections I ran a small wire to clear any incidental Plummer tape blockages. No leaks!
72doug2,2S 04-29-2025 03:44 AM
Originally Posted by Magyar Kiwi (Post 12455391)
Hi
Cheers
Since the pitting is at the very end would that come in contact with the square round rubber ring?
porsche930dude 04-29-2025 04:31 AM
I would use it. The corrosion on the end might only come in contact with the seal when the pads and rotors are brand new even then likely not or just barely.
911 Rod 04-29-2025 10:13 AM
That is before the seal. Just shine it up to remove the rust.
porsche passion 04-29-2025 01:28 PM
I've just done mine and they were similar. Clean it well and grey scotchbrite the pistons. It'll be fine.
72doug2,2S 04-29-2025 03:46 PM
As long as they don't come in contact with the rubber I think I'll reuse these.
Thanks all
