I’ve been searching here and in my Bentley book for the torque on the Supply side Cap.
Anyone know? I want to be sure to crush the copper washers properly!
PCA Member since 1988
Tight enough not to leak, and just a teensy bit more. Go by mechanic's feel.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
If you need a number, go with 8-10 ft lbs. BTW, It looks like there is teflon tape on the tank fitting. As the sealing takes place at the ball of the fitting not the threads, tape is not needed.
1986 Targa Guards Red 2021 MT09 SP |
Off topic a bit, but I am replacing my pump right now and looking at the PET there is a foam insulator for the fuel pump. Does it go between the bracket and the pump or on the side that just the clamp touches the pump?
What looks like tape is just the color under the black undercoat. There was tape masking it then that came off before fitting installation. Yeah definitely no teflon tape used 👍🏻
Jim D Western Ma. 1984 -911 Targa Previous owned 1969 911T |
Officially 14 ftlb
Great. I was pretty close to that. I will copy and put in my service book
