No Brake Lights !
I have just discovered that I have NO brake lights !!!!
I have checked everything and I have narrowed it down to the switch. Where is the brake light switch on a 83SC ? I found two switches attached to ther master cylinder and one actuator type switch in the tranny tunnel conneted to the clutch or something in the pedal cluster.In my recent move,I have misplaced my books.
Chuck
Old 07-06-2003, 07:05 PM
scottb's Avatar
I had the same problem with my 84. Replaced both switches on the master cylinder, and it solved the problem. They can be a bit "dicey" to remove because of all the plumbing in there, but it's a pretty simple job. Once the new ones were in, I was good to go.
1984 Targa
Old 07-06-2003, 08:10 PM
