Dave |
Dave... I did not take pics of the dynamic tests. Multimeter was set on 200 ac v.
Reference used: https://www.youtube.com/watch?v=zeFOOcLSk60 .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
![]() Just pulled. .
Are these 12.4 miles from cold? Or has the car already been fully warmed up to operating temp before conducting this test and calculating MPG?
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
What's the spark gap set at? Needs to be 0.7 to 0.8mm
But the color of all 6 plugs looks decent, those plugs do not look like they are running RICH. The 10MPG is likely not result of rich mixture, I suspect some sort of friction drag. Could be a sticking brake caliper or parking brake? Have you tests temps of rotors after a city drive?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Testing speed and ref sensors is best done with a scope. But honestly I don't think you have issues with crank sensors.
I really suspect some sort of mechanical drag in the drive train Your plug colors are not indicating overly rich mixture and all 6 are also showing that all cyls are firing.
Why did you write this; Quote:
Dave |
Also, I think you mentioned you have a Wide Band O2 gauge installed? If it shows reading in the 14s around town it confirms you are not burning extra fuel. Meaning the fuel is properly matched to the air intake. But you could still be taking in more air than normal because of mechanical friction?
Another worthy test is a 5 gas analyzer, this will also show hydro carbon, an indication of raw fuel in the exhaust. It could be helpful to get data from gas analyzer.
If the ref sensor was not working the engine would not start. Testing the ref/speed sensors is fine but likely not your issue. And you really need a scope to see the wave forms, and since engine runs I'd scope the sensors with engine running.
Make sure your distributor is phased correctly...shown is where it needs to be at TDC #1
I went through all the posts in this thread again today. The AFR city graphs clearly show you are in the correct target 1.0 lambda and you do not have black plugs nor black tailpipe. These 3 things tell us you are not running rich.
I'm not sure what the issue is here but it's most likely something mechanical. Double check all ignition components and firing order. Also 27-28MPG highway is on target and as expected. Some sort of extra mechanical drag is what I suspect, but not sure what that is. Could be collapsed brake hoses? Are these new? Test is easy to do, car on jack stand. Engine at idle in neutral. Have someone apply the brakes and attempt to turn a wheel by hand. Then have them remove foot from brake pedal. The MOMENT they lift off pedal the wheel MUST spin easily. If you find a delay between time they took foot off brake and wheel spins you have a bad hose.
Friction. Parking brakes were found months ago to have signs of dragging. Rebuilt both sides back then. Then checked mpg and wasn't the parking brakes. Calipers dragging - all wheels rotate freely. Wheel bearings - no rock of any wheel on its spindle. CV joints - no noticeable binding when rotating either rear wheel. And no crunching sound. Rears turn easily in or out of gear (rear end in the air.) Rotors - these were temp checked a few times over the months of this journey. Most recently a number of days ago. Last results are in post #56. Other friction checks & notes... Gearbox - fresh oil installed with rebuild and just checked level a few days ago - it's full & clean. Crank rotation - was checked months ago by tensioning belt, no spark plugs in, and turning crank by turning the fan. Not a problem turning the crank this way. During rebuild, galleys were all flushed. Bearings installed correctly. Engine temp operates at 210 with Mocal cooler in front fender, dual fans. When case was first closed, crank was turned to feel rotation - silky smooth. Journals were all polished. All were in spec for std. bearings. Rod large ends were rounded and bored to spec and new bushings went in on small ends, machining done by Total Engine Concepts up by Xtreme. Xtreme did heads. Pistons and cylinders were within spec. New Goetz rings were correctly installed. ARP rod bolts torqued to their spec. With each added section that was installed, the crank was turned over to feel for any anomaly. I'd have u-turned had any oddity in the least been sensed when doing these turns. Nothing was rushed. Break in was with a 20 minute run of engine at 2000 rpm. Engine oil & filter changed. Inspected oil and it looked good. Magnet too. I too am concluding it is as if the car is now moving an extra load, and the air & fuel are dialed into this "need." But, why only for city miles? Is momentum on the highway overcoming the friction if indeed friction is what it is? There is no question that what is in the car now in terms of weight is what was in the car when it was doing 18 city. Exception being the wideband system but that's negligible. So carrying actual added weight cannot be a factor. In the absence of actual added weight, it must be drag. More to the point, drag that only exists to get the car in motion. Not to keep it there. If I have missed a drag factor in the recent checks for it, what did I miss? __ Sal... conversation is appreciated. Looking again at the brakes ![]() .
Tire air pressure?
Gosh, you might drive it around in spirited manner and take an IR gun to the mechanicals, see what they tell you.
You would think all that fuel gets turned into Btu's some how and would leave a heat signature.
1980 911 - Metzger 3.6L 2016 Cayman S |
This thread reads like a mystery novel for Porsche nerds! I don’t understand many of the expert commentary, but sure looking for the exciting conclusion. Kudos to the original posters follow-up for each thought and comment. Extraordinary.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
We had a client one time complain about their fuel economy being much lower than advertised. It turned out their commute was only three miles each way.
The OP already found brake drag on the e-brake, once that was fixed MPG went from 10 to 12.
I suspect we still have some sort of brake drag occurring more often during city driving. I also assume he is comparing same city driving pattern and style from before rebuild to after?
Zuch... all good.
![]() Quote:
At a standing idle, it takes this engine, as it is now, 20 minutes to reach 210. Have timed this. I also know this engine can sit, running, in dead-stopped traffic indefinitely. Dirty engine with trombones... traffic can be a problem. I mention this for anyone overheating in traffic. Clean case and heads + fender Mocal with fans is a thermal solution. I went though this puzzle a few years ago. Quote:
Focus now is off the engine's running. All evidence combined at this moment suggests engine's doing what it should do... Wideband readings + plug color + engine's performance taken into combined account. I missed something in the hunt for friction. That hunt is now back on. .
Maybe you've been driving into headwinds recently???
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
What octane fuel are you using ?
Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
